Cisco 897VAG-LTE series router, can it be setup on FTTP NBN?
VULCA
Hello all! First time poster and newbie to networking here.
As a personal project and achievement I am hoping to get this 897 series router setup as my home network router as an upgrade from my stock rubbish iinet one.
I am led to believe it is possible with this router, I am just unsure as the cisco CLI is not something I have used before.
Can any experienced veterans help a lad out?
I am not really sure where to start in terms of deploying this thing. My networking teacher at TaFE (im a cert III student currently)  says that Cisco routers are a powerful tool to wield if you know how to use them correctly, especially on a trashy little home network.
Any pointers or insight would be greatly appreciated!
31 Replies 31
Hey mate,
I'm playing between GigabitEthernet8 & Ethernet0. once i get one up and running i know i'll be able to change a little bit of code between them and run either/or. Challenge I'm having atm is from my local pc i'm unable to get the internet to it.... Anything within the Startup-config stand out?
Also not sure how this static got to be there... And wondering if its causing my issues....
AussieBB#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 192.168.3.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 192.168.3.1
192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.3.0/24 is directly connected, GigabitEthernet8
L 192.168.3.10/32 is directly connected, GigabitEthernet8
