Cisco 899g - Cellular 0 interface unstable internet connection
jkwalker
I'm setting up a Cisco C899G-LTE router. When I initially connect to the router the seems good, I'm able to browse the web, ping google etc. However, the connection will drop off after approximately 6-12 minutes (not consistent). To reconnect, I must shutdown the cell 0 interface, change the cell 0 lte technology to either auto or lte (which ever it was not previously using), and then bring cell 0 back up. The only way I've found to avoid losing connection, is to continue to ping google at 30 sec intervals and not do any web browsing. Looking for suggestions on how to keep the connection from dropping.
Thanks!
-Jordan
post the running configuration of your router, maybe we can spot something...
Thanks for taking a look at it. I did add these three lines dialer
idle-timeout 0
dialer string lte
dialer persistent
This seems to have helped with the connection timing out to no-activity; however, trying to browse the web is still giving inconsistent timeouts. See full config below:
Building configuration...
Current configuration : 4099 bytes
! Last configuration change at 22:16:12 UTC Tue Dec 14 2021
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname Router1
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
ethernet lmi ce
no process cpu extended history
no process cpu autoprofile hog
no ip source-route
no ip gratuitous-arps
ip dhcp pool dpool1
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8 8.8.4.4
no ip bootp server
no ip domain lookup
ip domain name pme.local
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid C899G-LTE-NA-K9 sn FJC2232L19R
controller Cellular 0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
no cdp run
interface Loopback1
ip nat inside
ip virtual-reassembly in
interface Cellular0
ip address X.X.X.X 255.255.255.0
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
ethernet loopback permit internal vlan 1
interface Cellular1
no ip address
encapsulation slip
interface GigabitEthernet0
no ip address
no cdp enable
spanning-tree portfast
interface GigabitEthernet1
no ip address
no cdp enable
interface GigabitEthernet2
no ip address
no cdp enable
interface GigabitEthernet3
no ip address
no cdp enable
interface GigabitEthernet4
no ip address
no cdp enable
interface GigabitEthernet5
no ip address
no cdp enable
interface GigabitEthernet6
no ip address
no cdp enable
interface GigabitEthernet7
no ip address
no cdp enable
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface GigabitEthernet9
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface Dialer1
no ip address
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
no cdp enable
ip default-gateway 192.168.1.0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Cellular0
ip ssh version 2
no service-routing capabilities-manager
dialer-list 1 protocol ip permit
snmp-server community Corvette RO
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
no exec
rxspeed 100000000
txspeed 50000000
line 8
no exec
rxspeed 100000000
txspeed 50000000
line vty 0 4
exec-timeout 120 0
password
login local
transport input ssh
scheduler allocate 20000 1000
end
