01-21-2020 03:23 AM
Hi All,
I am looking at 9300 switch for one of my clients to support GRE and BGP( GRE between sites).
It needs to support 4 byte asn.
Feature navigator confirms it is supported on C9300-24T-A.
On feature navigator, I used keywork "BGP", "BGP Support for 4-byte ASN" and "Generic Routing Encapsulation" and IP SLA
Is there any other sub feature I need to check to ensure it does support it or has anyone got these model and can confirm it does?
01-21-2020 04:14 AM
the Feaure Navigator is not the most accurate tool to check for feature availability. Better to have a look at the datasheet for your specific model. In the link below, scroll down to the 'High-Performance IP Routing' section. BGPv4 is supported, so 4-byte ASNs are as well.
Table 13 in the 'Licensing' section of the document shows you the features that are available. For BGP and IP SLA, you need 'Network Advantage'.
01-21-2020 01:09 PM
01-21-2020 01:11 PM
it is only to receive default route
