IOS XR - RPKI erros
We would like to setup RPKI but we are facing to these errors when we try top setup and commit a route-policy to check RPKI validation state on IPs.
route-policy RP_RPKI in
!!% Could not find entry in list: Policy [RP_RPKI] uses the 'validation-state' attribute. There is no 'validation-state' attribute at the bgp neighbor-out-dflt attach point.
   route-policy RP_RPKI out
The route policy configuration is :
route-policy RP_RPKI1
if validation-state is invalid then
set community ($OWNASN:30) additive
drop
elseif validation-state is not-found then
set community ($OWNASN:20)
else
set community ($OWNASN:10)
endif
end-policy
Our IOS XR version is 6.4.2 on RSP 440.
Many thanks !
askoglund
It seems it complains on the fact that you are trying to apply it on the outgoing policy to check validation state which should be done in the incoming policy (which you also have applied). Are you trying to apply this to an iBGP neighbor ?
Also, have you enabled validation for the AF? (bgp origin-as validation enable)
looking at what you have posted, the name of the route policy is:
What you are attaching to your neighbor is:
Make sure that you do not simply have a typo...
Thanks for the reply, I made a wrong copy paste because I created two RPKI route-policy , the correct route policy is :
drop
else
endif
end-policy
Do you have any idea ?
That would have been too easy I guess..:)
I'll look further.
askoglund
