Cisco 9300X Static routes don't work to SVI Tunnels
Steve Adams
NOTE: I have done the same test setup with 4000 series routers, and routing works fine.
I have successfully setup 3 SVI (Static Virtual Interface) tunnels with IPSEC between 2 9300X switches.
- I can ping the tunnel IPs
- I can ping each VLAN interface on each side of the network from the switch cli
When a computer on the VLAN pings devices on the other side of the network, it is successful through the tunnel
When the computer tries to SSH to an IP on the other side, it ignores the static route and the traffic goes out the external interface.
I see that the 9300X can implement IPSEC tunnels, but it seems they left out the routing.
- Does the 9300X Catalyst Switch not support static routes to tunnel interfaces?
NEXUS 3172 Switch - In Between the 9300X switches
vlan 101
name SWITCH-1
vlan 102
name SWITCH-2
interface vlan101
10.0.101.2 255.255.255.0
interface vlan102
10.0.102.2 255.255.255.0
interface Ethernet1/1
description 9300X Switch1
switchport access vlan 101
interface Ethernet1/2
description 9300X Switch2
switchport access vlan 102
ip route 192.168.1.1/32 10.0.101.1 (Switch-1-Loopback)
ip route 192.168.2.1/32 10.0.102.1 (Switch-2-Loopback)
ip route 10.0.1.1/32 10.0.101.1 (Switch-1-Ext-Interface)
ip route 10.0.2.1/32 10.0.102.1 (Switch-2-Ext-Interface)
9300X Switch1 - IOS XE Version 17.13.1
vlan 172
name LAN172
interface vlan 172
ip address 172.16.1.1 255.255.255.0
interface loopback0
192.168.1.1 255.255.255.255
interface Tunnel1
ip address 10.0.1.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
tunnel source loopback0
tunnel mode ipsec ipv4
tunnel destination 192.168.2.1
tunnel protection ipsec profile IPSEC-IKEv2
interface TenGigabitEthernet1/0/1
description Switch-1-Ext-Interface
ip address 10.0.101.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.0.101.2
ip route 172.16.2.0 255.255.255.0 10.0.1.2
9300X Switch2 - IOS XE Version 17.13.1
vlan 172
name LAN172
interface vlan 172
ip address 172.16.2.1 255.255.255.0
interface loopback0
192.168.2.1 255.255.255.255
interface Tunnel1
ip address 10.0.1.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
tunnel destination 192.168.1.1
description Switch-2-Ext-Interface
ip address 10.0.102.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.0.102.2
Hello MHM,
UPDATE:  I did setup the network on my desk and routing worked fine.
I tried to simulate MTU values between 300-700 which occurs frequently with the (slow) satellite networks I work with, and I noticed that I can't even adjust the MTU on the 9300X switch below 824. I think this is my problem.
- This explains why the tunnels are UP/UP and ICMP works fine, but applications with a longer packer size don't work.
    - I am just confused why the SSH packet chose a different route than the ICMP
- I am also working with a cloud network with various SDWAN and Encryption tunnel overlay networks which complicates things.
I have come to the conclusion that the 9300X does route though the SVI tunnels as long as you have normal MTU sizes.
Thanks for all your inputs and suggestions!
-Steve
22 Replies 22
interface Tunnel1
ip address 10.0.1.2/1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
tunnel destination 10.0.1.1/2 <<- how tunnel destination is in same IP of tunnel? That can not be' you need to use tunnel destination the wan interface of other peer.
Yes, I messed up the typing out the config!   I was trying to not post the production config  GOOD CATCH!
I will fix the config = they are all loopback destinations.
interface Tunnel1
no ip redirects
no ip unreachables
no ip proxy-arp
vlan 172
name LAN172
interface vlan 172
interface loopback0
interface Tunnel1
no ip redirects
no ip unreachables
no ip proxy-arp
That good
Show ip interface breif
If the tunnel is up/up
Then only what you need is to specify the tunnel IP (10.x.x.x) in your ssh or telent' otherside the router is auto select interface and it seem that it not tunnel interface.
MHM
Hello MHM Cisco World,
In my production, there are 4 tunnels, and they are all UP/UP.   I have truncated the config-post here to simplify what I am trying to figure out.
Basically, in a nutshell, I have isr4300 routers, and I used the same exact configuration on the 9300X switch. (IOS XE)
Pings work from switch to switch, and from device to device on the VLANs on each side. I have ACLs on the tunnels and external interfaces. Pings will not work if the tunnels were not up, ping should be blocked if it tried to go out the external interface.
So, when I try and SSH from a device on the VLAN to another device on the VLAN across the tunnel, I see a DENY on the external interface - telling me that the static route is not working.
ip route 172.16.2.0 255.255.255.0 10.0.1.2   <= This is not working
I think my question is:  Should this work?  Does the Cisco Catalyst 9300X support routing to tunnel interfaces?
If it issue of routing then
Ping form side to side  must also drop' (I assume you use source IP in ping command that reache from other peer via tunnel)
So it issue of source of packet not issue of routing
MHM
Hello @Steve Adams ,
try to specify also the outgoing interface
ip route 172.16.2.0 255.255.255.0 10.0.1.2 tunnel1
Hope to help
Giuseppe
Thanks for the suggestion, I didn't think of that.
Steve
The problem is, when I am on a device that is on VLAN-172 on the first switch (172.16.1.10) and I try to SSH to a device on the second switch (172.16.2.10), I see a DENY on the outgoing ACL on my external interface, so I was very confused as to why the STATIC ROUTE = "ip route 172.16.2.0 255.255.255.0 10.0.1.2" is not working. The SSH traffic should have (chosen) the route through the TUNNEL, not the external interface:
ip access-group EXT_OUT out
ip access-group EXT_IN in
I have had a lot of problems with the 9300X switch like: object-groups do not work with ACLs, so I had to re-write all ACLs the old fashion way. And they do work that way, but, you are BLIND because counters do not work.
I feel like I have encountered another "Cisco BUG" where routing does not work through an SVI interface.
I am beginning to think that the 9300X is still a SWITCH, and routing through a tunnel is not supported.
  - But why would Cisco have tunnels work (up/up), but not routing through the tunnel?
I think the 9300X IOS XE is incomplete, the more I try to do with it, the more I find things don't work or it is BROKEN.
I am hoping it is something that I forgot and I missed.
Ok,
Then use what I usually do in dmvpn or any vpn
Use tunnel interface (egress interface) in static route instead of using tunnel IP
MHM
If this not work can you share acl you use? In and out acl
MHM
The ACL was very BASIC.
- Allow only HTTP/HTTPS/DNS  and DENY ALL.
NOTE: During all my testing, the web browsing and NON-TUNNEL traffic was routing/working fine.
NOTE: The IP Addresses used here are not the actual production IP's.
 - This is just for example purposes.
 - The External and Loopback interfaces are NON-PRIVATE IP's and are routable.
ip access-list extended EXT_OUT
 permit icmp any any echo
 permit icmp any any echo-reply
 permit icmp any any packet-too-big
 permit ip 192.168.0.0 0.0.7.255 192.168.0.0 0.0.7.255  (Tunnel IP -to Tunnel IP)
 permit ip 10.0.100.0 0.0.7.255 10.0.100.0 0.0.7.255 (EXT Interface -to- EXT Interface)
 permit tcp 172.16.1.0 0.0.0.255 any eq 80
 permit tcp 172.16.1.0 0.0.0.255 any eq 443
 permit udp 172.16.1.0 0.0.0.255 any eq 53
 deny ip any any log-input
ip access-list extended EXT_IN
 permit ip 192.168.0.0 0.0.7.255 192.168.0.0 0.0.7.255  (Tunnel IP Address Ranges)
 permit udp any eq 53 172.16.1.0 0.0.0.255
 permit tcp any any established
Thanks for your replies MHM!
Ok, but the traffic is as following
Inner IP add head
Scr vlan ip
Dest vlan ip
Outer IP add header
Src is tunnel source
Dest is tunnel dest
You permit tunnel IP not tunnel Scr and tunnel dest
Can you add line to permit it and check
MHM
Hello MHM
On the ACLs, I wanted only to permit the TUNNEL traffic from:
- LOOPBACK -to- LOOPBACK
- EXT-Interface -to- EXT-Interface
This is what is in production right now and is working fine.
INNER-VLAN traffic destined to the INNER-VLAN on the other side of the tunnel should NOT be leaked out of the external interface.
Flow:
INNER-VLAN1 <=> <IPSEC-TUNNEL/LOOPBACK> <=> EXT1 <=> EXT2 <=> <IPSEC-TUNNEL/LOOPBACK> <=> INNER-VLAN2
As I was looking at the logs, I did see a few ICMPs being denied from what looks to me, remote routers in the cloud.
- This may be Path-to-MTU-Discovery
A good question would be, if the TUNNEL is UP/UP, but the MTU was NOT adjusting because of the ICMP is being blocked from remote routers, would that effect routing so that re-directs out the default route instead of the static route?
I do see the same ICMP blocks on the isr4300 router, but it is working. So I am like  Hmmmm....
Thanks!
Steve
Sorry I will continous to ask you some Q about issue' I dont think it routing issue'
Lan1-Sw1-Sw2-Lan2
If you start SSH from LAN2 to LAN1 this will failed becuase you use established keywords in ACL IN' which allow only TCP if session initiate from LAN1.
MHM
