Unable to ping between two tunnel points
noforshow92
Hello, I built using the packet tracer a simple topology of three routers with ospf routing. I created a tunnel between the two routers that are not physically connected to each other, but I can't ping between one end and the other. I managed to ping between two in loopbacks.
hanks for all replies.
Router#show run
Building configuration...
Current configuration : 1084 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152412Z5-
spanning-tree mode pvst
interface Loopback0
ip address 10.10.10.254 255.255.255.0
interface Tunnel0
ip address 100.100.100.10 255.255.255.0
mtu 1476
tunnel source Loopback0
tunnel destination 20.20.20.254
interface GigabitEthernet0/0
ip address 10.0.1.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.0.5.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.1.0 0.0.0.255 area 0
network 192.168.1.1 0.0.0.0 area 0
network 100.100.100.0 0.0.0.3 area 0
network 10.0.5.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
____________________________________________
Router#show run
version 15.1
hostname Router
ip cef
no ipv6 cef
interface Loopback0
interface Tunnel0
mtu 1476
duplex auto
speed auto
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Hi @noforshow92 ,
I made the modification to use the physical interface instead of the loopback interface as recommended previously and it works for me.
Router2:
interface Tunnel0
mtu 1476
tunnel source GigabitEthernet0/0
tunnel destination 10.0.2.1
Router1:
interface Tunnel0
ip address 100.100.100.20 255.255.255.0
mtu 1476
tunnel source GigabitEthernet0/1
tunnel destination 10.0.1.1
Router#ping 100.100.100.10
Sending 5, 100-byte ICMP Echos to 100.100.100.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/0 ms
Router#ping 100.100.100.20
Sending 5, 100-byte ICMP Echos to 100.100.100.20, timeout is 2 seconds:
20 Replies 20
Harold Ritter
Hi @noforshow92 ,
You attached the same configuration twice, but what we can see from this configuration. You use the loopback0 as the source for the tunnel interface, but you don't advertise loopback0 in ospf. I would recommend you change the following:
interface Loopback0
ip address 10.10.10.254 255.255.255.255
router ospf 1
network 10.10.10.254 0.0.0.0 area 0
Make sure you do the same on the router.
HI harold, thank you very much for the answer.
I added the loopbacks in ospf on both routers
router ospf 1
network 10.10.10.0 0.0.0.255 area 0
__________
router ospf 1
network 10.0.2.0 0.0.0.255 area 0
network 192.168.1.2 0.0.0.0 area 0
network 0.0.0.0 255.255.255.255 area 0
network 10.0.8.0 0.0.0.255 area 0
network 20.20.20.0 0.0.0.255 area 0
I manage to ping between the two loopbacks, but still can't ping between the two ends of the tunnel (I managed to ping between the loopbacks before as well)
Hi @noforshow92 ,
Can you attach the following information for both tunnel endpoints:
show ip route
show runn int tu0
Router 1
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.0.1.0/24 is directly connected, GigabitEthernet0/0
L 10.0.1.1/32 is directly connected, GigabitEthernet0/0
O 10.0.2.0/24 [110/2] via 10.0.1.2, 02:47:42, GigabitEthernet0/0
C 10.10.10.254/32 is directly connected, Loopback0
20.0.0.0/32 is subnetted, 1 subnets
O 20.20.20.254/32 [110/3] via 10.0.1.2, 02:47:42, GigabitEthernet0/0
100.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 100.100.100.0/24 is directly connected, Tunnel0
L 100.100.100.10/32 is directly connected, Tunnel0
Router#show interfaces tunnel 0 | include destination
Tunnel source 10.10.10.254 (Loopback0), destination 20.20.20.254
Router 2
O 10.0.1.0/24 [110/2] via 10.0.2.2, 02:48:02, GigabitEthernet0/1
C 10.0.2.0/24 is directly connected, GigabitEthernet0/1
L 10.0.2.1/32 is directly connected, GigabitEthernet0/1
O 10.10.10.254/32 [110/3] via 10.0.2.2, 01:30:32, GigabitEthernet0/1
C 20.20.20.254/32 is directly connected, Loopback0
L 100.100.100.20/32 is directly connected, Tunnel0
Tunnel source 20.20.20.254 (Loopback0), destination 10.10.10.254
Never Never
Make tunnel source and tunnel IP in same IGP
Remove the tunnel IP subnet from ospf
And ypu can ping tunnel IP directly no need ospf (or any IGP)
Just do
Ping < tunnel IP peer2 > source < tunnel IP peer1>
Note in ping I use tunnel IP not tunnel source or destination
MHM
HI,
I removed the IP of the tunnel from the ospf list, but I still can't ping the IP of the tunnel at the other end
router ospf 1
show ip interface brief
and share how you ping (I need to see command you use)
MHM
Here:
Router 1
Router#show ip interface brief
GigabitEthernet0/0 10.0.1.1 YES manual up up
GigabitEthernet0/1 10.0.5.1 YES manual up down
GigabitEthernet0/2 unassigned YES unset administratively down down
Loopback0 10.10.10.254 YES manual up up
Tunnel0 100.100.100.10 YES manual up up
Vlan1 unassigned YES unset administratively down down
Router 2
GigabitEthernet0/0 10.0.8.1 YES manual up down
GigabitEthernet0/1 10.0.2.1 YES manual up up
Loopback0 20.20.20.254 YES manual up up
Tunnel0 100.100.100.20 YES manual up up
ping
Success rate is 0 percent (0/5)
ping 100.100.100.20 source 100.100.100.10
do this
MHM
I'm sorry, what do you mean source 100.100.100.10?
I'm pinging from router 2 (the one with the loopback 10.10.10.254) to 100.100.100.20
Hi @noforshow92 ,
I believe the tunnel not working when using the loopback interface is some kind of Packet Tracer limitation. Try using the physical interface addresses as the tunnel source and destination and it should work.
HI Harold,
I changed the source from the loopbacks to one of the physical ports, but still can't send a ping to the address of the tunnel
O 10.0.1.0/24 [110/2] via 10.0.2.2, 00:58:57, GigabitEthernet0/1
O 10.0.5.0/24 [110/3] via 10.0.2.2, 00:16:58, GigabitEthernet0/1
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.0.6.0/24 is directly connected, GigabitEthernet0/2
L 20.0.6.1/32 is directly connected, GigabitEthernet0/2
Tunnel source 20.0.6.1 (GigabitEthernet0/2), destination 10.0.5.1
10.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
O 10.0.2.0/24 [110/2] via 10.0.1.2, 01:06:06, GigabitEthernet0/0
C 10.0.5.0/24 is directly connected, GigabitEthernet0/1
L 10.0.5.1/32 is directly connected, GigabitEthernet0/1
C 10.10.10.0/24 is directly connected, Loopback0
L 10.10.10.254/32 is directly connected, Loopback0
20.0.0.0/24 is subnetted, 1 subnets
O 20.0.6.0/24 [110/3] via 10.0.1.2, 01:04:52, GigabitEthernet0/0
Tunnel source 10.0.5.1 (GigabitEthernet0/1), destination 20.0.6.1
Hi @noforshow92 ,
Could you please zip the packet trace file and upload so we can check it.
