Cisco 9800 mdns Service Instance List
piotrPaszk
Hi wifi champions :)
I am migrating the old config from 8540 to 9800 but I am scrapping my head around Service Instance List which was available on the old one. I could define there which device is visible where ( location, ap, ap group) Whare is such functionality on the 9800 ?
Br
Piotr
Scott Fella
Take a look at this guide showing specific LSS definitions.
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/9800/17-1/deployment-guide/c9800-mdns-deployment-guide-rel-17-1.pdf
-Scott
Hi Scott,
Thanks for the answer :) but how to get controll over the wired devices. It the guide there is a Note: Wired Service Instances can’t be subjected to Site-tag, LSS or Location-based filtering and will always be responded unless configured otherwise. What does it mean otherwise ????
At the moment the students can print to any printer in the organization which I want to limit to only one UNIFLOW server.
Do you have any tips on how to do it ?
Best regards,
Piotr
