Cisco and Zoneedit
ikhan
Any one got experience with Cisco 3620 routers doing automatic updates of ip addresses with zoneedit?
I hav a non-static ip address and want the router to do an update when the ipaddress on the interface changes.
Any help would be much appreciiated.
Ikhan
b.hsu
Level 5
Level 5
Specify the DynDNS.org to process the updates with Zone-edit.It could be done with the help of the following command
PASSWORD@www.zoneedit.com/auth/dynamic.html?host')">http://USERNAME:PASSWORD@www.zoneedit.com/auth/dynamic.html?host=&dnsto=.Refer the following URL
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a00804461ba.html
I was able to make it work with  IOS 15.
As far as i tested it doesnt work with IOS 12.4. Same  exact config with IOS 15 and it works.
**** IOS 15 its very buggy, there is  another way, using "ip sla" command, i was able to make it work with  "freedns.afraid.org", witch too offers free dns/ddns services with  custom top level domains.
You can check it out here:
http://www.tiagomarques.info/2010/11/tuturial-cisco-ddns-e-freedns-afraid-org/
Note: Its  in Portuguese, **** everyone should figure out the important stuff.
