Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco asa 5505 not reaching my download speeds
walters199
We try to replace our Palo Alto to an ASA 5505.
We have a Fiber line with 100mb up/down.
Upload is a constant 80/90 mb
Download keeps stuck at 35/40 mb
I have tried al the solutions mentioned on
https://www.reddit.com/r/Cisco/comments/2u4o3n/asa_5505_bottlenecking_100mbps_internet_to_35mbps/
- We have no shapers configured
- The interface is set to 100mb full duplex
- used Gb switch between ISP and my ASA
I have searcht around but can`t find a solution.
Config below:
!!! I have noticed the CRC errors.
For the inside interface I replaced all my cables ( Numbers grow only with uploading where I have no troubles at the moment)
The CRC errors on the outside are from messing with the cables.
Any Ideas ?
interface Ethernet0/0
description FIBER
speed 100
duplex full
interface Ethernet0/1
switchport access vlan 10
speed 100
duplex full
interface Vlan1
nameif outside
security-level 0
pppoe client vpdn group FIBER
ip address pppoe setroute
interface Vlan10
nameif DATA
security-level 100
mtu outside 1500 ( tried with 1492)
mtu DATA 1500
mtu SERVERS 1500
mtu MGT 1500
sysopt connection tcpmss 1452
FW-01# sh interface ethernet 0/0
Interface Ethernet0/0 "", is up, line protocol is up
Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Input flow control is unsupported, output flow control is unsupported
Description: FIBER
Available but not configured via nameif
MAC address 30f7.0d2e.57c7, MTU not set
IP address unassigned
1411457 packets input, 1296786629 bytes, 0 no buffer
Received 8 broadcasts, 0 runts, 0 giants
2167 input errors, 2167 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
3288 switch ingress policy drops
1768813 packets output, 1918191234 bytes, 0 underruns
0 pause output, 0 resume output
6999 output errors, 1399 collisions, 0 interface resets
0 late collisions, 340 deferred
0 rate limit drops
0 switch egress policy drops
0 input reset drops, 0 output reset drops
Interface Ethernet0/2 "", is up, line protocol is up
MAC address 30f7.0d2e.57c9, MTU not set
684095 packets input, 690945987 bytes, 0 no buffer
Received 1886 broadcasts, 0 runts, 0 giants
4241 input errors, 4241 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
1336 switch ingress policy drops
596307 packets output, 570227296 bytes, 0 underruns
0 late collisions, 0 deferred
0 rate limit drops
FW-01# sh service-policy
Global policy:
Service-policy: global_policy
Class-map: inspection_default
Inspect: dns preset_dns_map, packet 4454, drop 10, reset-drop 0, v6-fail-close 0
Inspect: ftp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: h323 h225 _default_h323_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
tcp-proxy: bytes in buffer 0, bytes dropped 0
Inspect: h323 ras _default_h323_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: ip-options _default_ip_options_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: netbios, packet 3, drop 0, reset-drop 0, v6-fail-close 0
Inspect: rsh, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: rtsp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: skinny , packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: esmtp _default_esmtp_map, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: sqlnet, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: sunrpc, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: tftp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
Inspect: sip , packet 1484, drop 0, reset-drop 0, v6-fail-close 0
Inspect: xdmcp, packet 0, drop 0, reset-drop 0, v6-fail-close 0
policy-map global_policy
class inspection_default
inspect dns preset_dns_map
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
FW-01# sh version
Cisco Adaptive Security Appliance Software Version 9.1(2)
Device Manager Version 7.1(3)
Compiled on Thu 09-May-13 15:37 by builders
System image file is "disk0:/asa912-k8.bin"
Config file at boot was "startup-config"
FW-01 up 1 hour 30 mins
Hardware: ASA5505, 1024 MB RAM, CPU Geode 500 MHz,
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
First: The 5505 is rated for 150 MBit/s with UDP under ideal test conditions. Whatever you configure, this device is to slow for your connection.
You still can try to improve the result a little bit:
  1. Make sure that your duplex-settings match the other side. The collisions/CRC errors should not increment any more
  2. Upgrade to the newest code.
  3. With PPPoE, an MTU of 1492 is correct.
  4. Disable all unneeded inspections in your policy-map
But whatever you do, you won't reach line-rate.
Hi Karsten,
Thank you for your reply. I appreciate it.
I will ask my collegue from sales to look for a newer ASA 5508. I just checkt the capacity sheet and this device will probably reach the maximum troughput.
You should be getting more than 35/40Mbps down.
I use a 5505 for my home connection and have 100/10 from my provider.  I just tested and was getting 87 down and a little over 10 up.  If you're getting half that, something is wrong.
I would double check the devices this ASA is connecting to.  I once had the same issue you're describing at home and it was due to me hard-coding the ASA at 100/Full, but the service provider modem was at Auto, and they auto-negotiated at Half duplex.
Again, double check all connection points for duplex/speed mismatches.  That would be my first step.  But you should expect more than 40Mbps out of this device.
Thank for your reply Scott.
I will connect the asa again and see if it auto duplexes to full.
And confirm at the ISP if there device  also trains in at 100Mb full-duplex.
