CISCO ASA 5505 TCP connection issue
I am facing issues in connecting a pc from outside interface to dmz interface on cisco 5505 asa firewall. The icmp ping is successfull from outside pc to dmz server but failed to establish any tcp connection.
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
switchport access vlan 3
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 2
interface Vlan1
nameif inside
security-level 100
ip address 10.1.1.6 255.255.255.252
interface Vlan2
nameif outside
security-level 0
ip address 10.1.1.1 255.255.255.248
interface Vlan3
no forward interface Vlan1
nameif DMZ
security-level 50
ip address 10.1.1.10 255.255.255.252
object network dmz
host 10.1.1.9
object network inside
host 10.1.1.5
route outside 0.0.0.0 0.0.0.0 10.1.1.2 1
access-list icmp_http_ftp extended permit icmp any object inside
access-list icmp_http_ftp extended permit icmp any object dmz
access-list icmp_http_ftp extended permit tcp any object dmz eq www
access-list icmp_http_ftp extended permit tcp any object dmz eq ftp
access-group icmp_http_ftp in interface outside
object network dmz
nat (DMZ,outside) static 10.1.1.3
nat (inside,outside) dynamic interface
class-map cmap
match default-inspection-traffic
policy-map pmap
class cmap
inspect ftp
inspect http
inspect icmp
service-policy pmap global
telnet timeout 5
ssh timeout 5
Kindly can anyone provide feedback of where i am going wrong.
6 Replies 6
if this is a Packet Tracer project, post the zipped .pkt file. Your OUTSIDE VLAN2 uses subnet 10.1.1.0/29 which includes 10.1.1.1 - 10.1.1.6, your inside Vlan 1 (10.1.1.6/30) overlaps, is that on purpose ?
No that is not done on purpose.
I am attaching the .pkt file, please find me some sollution for this as i am not able to understand where i am going wrong.
I'll have a look.
How do you establish the TCP connection ?
Using pc2 web browser and server is statically natted with public ip (10.1.1.3/29) to the outside interface of firewall.
I think you need to set up a DNS server and add at least one A record. If you try to access the server on HTTP (PC1 to Server1) on the inside Vlan (without the firewall being involved) you do not get a response either.
Hello
object network dmz
host 10.1.1.9
host 10.1.1.5
object network dmz
class-map cmap
Try the following -- you need to readdress vlan 1 subnet!
no object network dmz
no access-list icmp_http_ftp extended permit icmp any object inside
no access-list icmp_http_ftp extended permit icmp any object dmz
no access-list icmp_http_ftp extended permit tcp any object dmz eq www
no access-list icmp_http_ftp extended permit tcp any object dmz eq ftp
no access-group icmp_http_ftp in interface outside
interface Vlan1
ip address 10.1.1.13 255.255.255.252
host 10.1.1.14
object network dmz_public
host 10.1.1.3
object network dmz_www
host 10.1.1.9
nat (DMZ,outside) static object dmz_public service www www
object network dmz_ftp
host 10.1.1.9
nat (DMZ,outside) static object dmz_public service ftp ftp
access-list icmp_http_ftp extended permit icmp any interface inside echo-reply
access-list icmp_http_ftp extended permit icmp any interface DMZ echo-reply
access-list icmp_http_ftp extended permit tcp any host 10.1.1.3 eq www
access-list icmp_http_ftp extended permit tcp any host 10.1.1.3 eq ftp
Kind Regards
Paul
