02-01-2021 06:05 AM - edited 02-01-2021 06:09 AM
Hy Everyone!
I got a router from my company and I have to configure it. I tried to set with default settings but it was unsuccessful.
The WAN IP, mask dns, gateway what I got it works when I connect to directly to the computer and I set on the adapter.
I can to the CIsco router as well and I can ping 8.8.8.8 from the router via ASDM.
I got IP address from the router 192.168.1.5 and I can ping the router but there is no internet access.
It is a default setting wit default nat rules. I just set the g1/1 to wan.
So INSIDE > OUTSIDE not working.
Anyone can help out?
: Serial Number: JAD23131AVE
: Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.8(2)
hostname ciscoasa
names
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 194.xxx.xxx.xxx 255.255.255.252
interface GigabitEthernet1/2
bridge-group 1
nameif inside_1
security-level 100
interface GigabitEthernet1/3
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet1/4
bridge-group 1
nameif inside_3
security-level 100
interface GigabitEthernet1/5
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet1/6
bridge-group 1
nameif inside_5
security-level 100
interface GigabitEthernet1/7
bridge-group 1
nameif inside_6
security-level 100
interface GigabitEthernet1/8
bridge-group 1
nameif inside_7
security-level 100
interface Management1/1
management-only
no nameif
no security-level
no ip address
interface BVI1
nameif inside
security-level 100
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 62.xxx.xxx.10
same-security-traffic permit inter-interface
object network obj_any1
subnet 0.0.0.0 0.0.0.0
object network obj_any2
object network obj_any3
object network obj_any4
object network obj_any5
object network obj_any6
object network obj_any7
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside_6 1500
mtu inside_7 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside_1,outside) dynamic interface
nat (inside_2,outside) dynamic interface
nat (inside_3,outside) dynamic interface
nat (inside_4,outside) dynamic interface
nat (inside_5,outside) dynamic interface
nat (inside_6,outside) dynamic interface
nat (inside_7,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 194.xxx.xxx145 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 inside_1
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 192.168.1.0 255.255.255.0 inside_6
http 192.168.1.0 255.255.255.0 inside_7
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
prompt hostname context
no call-home reporting anonymous
Solved! Go to Solution.
02-01-2021 06:26 AM
why there is so many BVI interfaces ? is this what you looking to configure.
if BVI is not your intention then check this :
02-01-2021 06:10 AM
Suggest to review the config below URL help you - quick start working with ISP.
https://www.networkstraining.com/cisco-asa-5506-x-configuration-tutorial-guide/
https://www.cisco.com/c/en/us/td/docs/security/asa/quick_start/5506X/5506x-quick-start.html
If you still have issue please, post show run from ASA, so we can tweak for you.
02-01-2021 06:15 AM
I've edited the post I ran the command. Now it contains respons.
02-01-2021 06:17 AM
I seems that there is no transition or it is not working between inside<>outside.
02-01-2021 06:26 AM
02-03-2021 02:13 AM
Thank you!!
Afther delete BVI and configure each interface, it has been started working.
04-20-2021 07:00 AM
Tengo mas o menos el mismo problema, intente con la sugerencia pero no me permite eliminar el BVI me sale un error adjunto imagen del error:
Seguí los pasos para poder eliminar pero aun así me sales el error, si tienes alguna sugerencia o algún paso mas a seguir te agradecería mucho.
Gracias
04-20-2021 07:37 AM
Not sure what is the issue,
Can you open a new thread with english, so we can address correctly.
