Cisco ASA IPV6 Issues when LAN machines try to ping
cogenyk
I am setup to get IPV6 over DHCP with my ISP, i can access the internet and ping IPv6 from the console but not the local machines, i think maybe i have a routing issue or something, im not sure.
Ive linked a paste bin with several run's of debugging commands.
https://pastebin.pl/view/3234a346
Hi @cogenyk ,
You first need to validate that you do receive the delegated prefix from the service provider using the following command:
show ipv6 general-prefix
you then need to apply that delegated prefix to the inside interface in the following way and remove the extra unnecessary command.
interface GigabitEthernet0/1
 ipv6 address Outside-Prefix ::1/64
 no ipv6 address dhcp
I would also recommend changing the following configuration on the outside interface:
interface GigabitEthernet0/0
 ipv6 address dhcp default
 no ipv6 nd managed-config-flag
 no ipv6 nd other-config-flag
Let us know how it goes.
10 Replies 10
Harold Ritter
Hi @cogenyk ,
You use a unique local address (ULA) on the inside interface. These ULA are not routable on the Internet. The best option would be to configure ipv6 prefix delegation on the ASA. Your inside interface will therefore get a global prefix and your local machine will be able to access the Internet. Please refer to the following document to fond out how you can configure ipv6 prefix delegation on the ASA.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa913/configuration/general/asa-913-general-config/interface-routed-tfw.html#id_65842
Hello @Harold Ritter,
Im not sure what I should be using as my prefix since I get an error,
This is as far as i got
 nameif OUTSIDE
 security-level 0
 ip address dhcp
 ipv6 address autoconfig
 ipv6 address dhcp
 ipv6 enable
 ipv6 dhcp client pd hint 2604:3d08:5:13:24e3:4d73:c673:9745/128
 ipv6 dhcp client pd Outside-Prefix
 nameif INSIDE
 security-level 100
 ip address 10.0.0.1 255.255.254.0
 ipv6 enable
try and configure:
on the inside interface...what address do you get ?
Hi @cogenyk ,
The hint is about the delegated prefix you expect to receive, not about the address you got on the outside interface. It is optional. Try removing the hint. It should fix it.
no ipv6 dhcp client pd hint 2604:3d08:5:13:24e3:4d73:c673:9745/128
@Georg Pauwen
INSIDE is up, line protocol is up
IPv6 is enabled, link-local address is fe80::4e4e:35ff:feeb:919
No global unicast address is configured
Joined group address(es):
ff02::1:ffeb:919
ff02::2
ff02::1
ICMP error messages limited to one every 100 milliseconds
ICMP redirects are enabled
ND DAD is enabled, number of DAD attempts: 1
ND reachable time is 30000 milliseconds
ND advertised reachable time is 0 milliseconds
ND advertised retransmit interval is 1000 milliseconds
ND router advertisements are sent every 200 seconds
ND router advertisements live for 1800 seconds
Hosts use stateless autoconfig for addresses.
Hosts use DHCP to obtain other configuration.
@Harold Ritter Applied change as noted ; did not change results.
Hi @cogenyk ,
Can you apply the following modification:
no ipv6 address autoconfig
ipv6 dhcp client pd hint ::/56
Can you also do a shut/no shut on the outside interface to reinitialize it.
Still not able to ping IPv6 addresses,
Ran commands as requested
OUTSIDE is up, line protocol is up
  IPv6 is enabled, link-local address is fe80::4e4e:35ff:feeb:91c
  Global unicast address(es):
    2604:3d08:5:13:24e3:4d73:c673:9745, subnet is 2604:3d08:5:13:24e3:4d73:c673:9745/128
    ff02::1:ff73:9745
    ff02::2
    ff02::1:ffeb:91c
    ff02::1
  Hosts use DHCP to obtain routable addresses.
    ff02::1:ffeb:919
    ff02::2
    ff02::1
Servers is up, line protocol is up
  IPv6 is enabled, link-local address is fe80::5133:32ac:771:b2db
 nameif OUTSIDE
 security-level 0
 ip address dhcp
 ipv6 address dhcp
 ipv6 enable
 nameif INSIDE
 security-level 100
 ipv6 address dhcp
 ipv6 enable
@Harold Ritter / @Georg Pauwen
Hi @cogenyk ,
Ok,
IPv6 Prefix Outside-Prefix, acquired via DHCP PD
  2604:3d09:c580:151::/64 Valid lifetime 138151, preferred lifetime 138151
   Consumer List                Usage count
    INSIDE (Address command)    1
ciscoasa#
ran the commands as suggested, can now ping on the ASA CLI, pings on LAN now work!
Hi @cogenyk ,
Glad to know it now works. Let us know if there is anything else.
