Cisco ASA - No internet access from inside hosts
Hi. I have the following situation.
ASA 5512-X running ASA software 9.8.4(tried also with 9.10) and on that ASA the following configuration:
- 1 WAN connection - Public ip address - direct connection RJ45
- 1 WAN connection - Pubilc ip address - via PPPoE
- 1 INSIDE interface
- 1 Interface link to a Cisco 6500
- Anyconnect remote VPN access and also Ipsec VPN tunnels both normal IPsec and VTI interfaces over ipsec.
Out of this whole setup i cannot get the hosts on the INSIDE interface to get out on the internet.
Anyconnect is working and you can login and also does NAT for the vpn subnet.
the VTI interfaces and the othe IPSEC tunnels work fine.
Routing to and from the 6500 is perfect as well.
Runing packet tracer it shows the connection being dropped by the implicit rule but i do have an allow any any rule.
I have checked inter-interface and intra-interface settings and are fine. all routing looks also fine yet no internet access.
I'll add the config below maybe somebody can give me an idea of what it could be and how to fix it.
hostname Asa-VPN
enable password  encrypted
passwd  encrypted
names
ddns update method http
ddns both
interval maximum 0 0 5 0
no mac-address auto
ip local pool VPN-DHCP-Pool 192.168.245.10-192.168.245.25 mask 255.255.255.0
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 193.x.x.x 255.255.255.224
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.10.1.1 255.255.255.0
interface GigabitEthernet0/2
nameif cisco6500
security-level 100
ip address 10.254.2.2 255.255.255.252
interface GigabitEthernet0/3
description rds
nameif rdspppoe
security-level 0
pppoe client vpdn group rds
pppoe client route distance 10
ip address pppoe setroute
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
interface Tunnel1
nameif Benny-VTI
ip address 10.20.0.1 255.255.255.252
tunnel source interface outside
tunnel destination y.y.y.y
tunnel mode ipsec ipv4
tunnel protection ipsec profile Benny-Profile
interface Tunnel2
nameif Alex-VTI
ip address 192.168.60.2 255.255.255.252
tunnel destination z.z.z.z
tunnel protection ipsec profile alex-proposal
boot system disk0:/asa984-smp-k8.bin
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Fri Apr 0:00 last Fri Sep 0:00
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network NETWORK_OBJ_192.168.245.0_27
subnet 192.168.245.0 255.255.255.224
object network inside-subnet-outside
subnet 10.10.1.0 255.255.255.0
object network vpn-out-main
object network xxxxx
subnet 192.168.88.0 255.255.255.0
object network inside-subnet-rdspppoe
object network vpn-out-rds
object network vpn-subnet
object network mineri
subnet 10.254.1.0 255.255.255.0
subnet 192.168.0.0 255.255.255.0
host 79.97.165.193
object network storage
subnet 10.40.255.0 255.255.255.0
object network xxxx
subnet 10.254.5.0 255.255.255.0
object network vps-docker-01
host 10.10.1.5
object network inter-cisco
subnet 10.254.2.0 255.255.255.252
object network docker-01-ccx
host 10.10.1.5
object network outside-ip
host x.x.x.x
object network obj_any
subnet 0.0.0.0 0.0.0.0
object-group network DM_INLINE_NETWORK_3
network-object object gabi
network-object object mineri
object-group network DM_INLINE_NETWORK_1
network-object object xxxx
object-group service DM_INLINE_TCP_2 tcp
port-object range 10001 10002
port-object eq 10070
port-object eq 11070
port-object range 13280 13281
port-object eq 15000
port-object eq 16000
port-object eq 1811
port-object eq 2222
port-object eq 26942
port-object eq 26943
port-object eq 61208
port-object eq 8070
port-object eq 8071
access-list outside_access extended permit tcp any4 object vps-docker-01 eq 16000 log debugging
access-list vpn extended permit ip object vpn-subnet any
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any4 host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any4 any4 eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any4 any4 eq netbios-ns
access-list AnyConnect_Client_Local_Print extended deny ip any4 any4
access-list global_access extended permit ip any any log debugging
access-list outside_cryptomap extended permit ip object-group DM_INLINE_NETWORK_1 object dubai
access-list inside_access_in extended permit ip any any log debugging
pager lines 24
logging enable
logging buffered debugging
logging asdm debugging
logging class webvpn console debugging
mtu outside 1500
mtu inside 1500
mtu cisco6500 1500
mtu rdspppoe 1492
mtu management 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside
icmp permit any cisco6500
icmp permit any rdspppoe
asdm image disk0:/asdm-7101.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
nat (any,outside) source static DM_INLINE_NETWORK_1 DM_INLINE_NETWORK_1 destination static dubai dubai no-proxy-arp route-lookup
nat (any,outside) dynamic interface
nat (inside,rdspppoe) dynamic interface
nat (any,rdspppoe) dynamic interface
access-group outside_access in interface outside
access-group inside_access_in in interface inside
access-group global_access global
router bgp 65343
bgp log-neighbor-changes
bgp graceful-restart
timers bgp 10 32 0
address-family ipv4 unicast
  neighbor 192.168.60.1 remote-as 34555
  neighbor 192.168.60.1 activate
  neighbor 192.168.88.1 remote-as 65500
  neighbor 192.168.88.1 ebgp-multihop 255
  neighbor 192.168.88.1 activate
  neighbor 10.20.0.2 remote-as 65000
  neighbor 10.20.0.2 ebgp-multihop 10
  neighbor 10.20.0.2 timers 10 30 30
  neighbor 10.20.0.2 activate
  network 10.10.1.0 mask 255.255.255.0
  network 10.254.1.0 mask 255.255.255.0
  network 10.254.5.0 mask 255.255.255.0
  network 10.40.255.0 mask 255.255.255.0
  bgp suppress-inactive
  no auto-summary
  no synchronization
exit-address-family
route outside 0.0.0.0 0.0.0.0 x.x.x.129 1 track 1
route cisco6500 10.40.255.0 255.255.255.0 10.254.2.1 1
route cisco6500 10.254.1.0 255.255.255.0 10.254.2.1 1
route cisco6500 10.254.5.0 255.255.255.0 10.254.2.1 1
route Null0 192.168.245.0 255.255.255.224 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication login-history
http server enable 4443
http server idle-timeout 180
http server session-timeout 180
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 inside
http 0.0.0.0 0.0.0.0 outside
sysopt connection tcpmss 1460
sysopt noproxyarp rdspppoe
sla monitor 1
type echo protocol ipIcmpEcho 8.8.8.8 interface outside
sla monitor schedule 1 life forever start-time now
sla monitor 2
type echo protocol ipIcmpEcho 192.168.88.1 interface outside
timeout 1000
frequency 3
sla monitor schedule 2 life forever start-time now
crypto ipsec ikev1 transform-set aes esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set benny esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set alex-transform esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set toxx esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set test-alex esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set test-alex mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto ipsec profile alex-test-prop
set ikev1 transform-set test-alex
set pfs group2
set security-association lifetime seconds 1800
crypto ipsec profile Benny-Profile
set ikev1 transform-set benny
set pfs group5
set security-association lifetime kilobytes 10000
set security-association lifetime seconds 3600
crypto ipsec profile alex-proposal
set ikev1 transform-set alex-transform
set pfs group5
crypto ipsec profile toxx-transform
set ikev1 transform-set toxx
set pfs group2
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association replay window-size 128
crypto ipsec security-association pmtu-aging infinite
crypto ipsec df-bit clear-df outside
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 94.203.254.169
crypto map outside_map 1 set ikev1 transform-set toxx
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto map rdspppoe_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map rdspppoe_map0 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map rdspppoe_map0 interface rdspppoe
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=ciscoasa
proxy-ldc-issuer
crl configure
crypto ca trustpoint ASDM_TrustPoint1
keypair ASDM_TrustPoint1
crl configure
crypto ca trustpoint ASDM_TrustPoint2
enrollment terminal
crl configure
crypto ca trustpool policy
crypto isakmp identity address
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 2
encryption aes-256
integrity sha256
group 19
prf sha256
crypto ikev2 policy 3
encryption aes-256
integrity sha256
group 19
prf sha
crypto ikev2 policy 4
encryption aes-256
integrity sha
group 5 2
prf sha
crypto ikev2 policy 5
encryption aes-256
integrity sha256
group 5 2
prf sha
crypto ikev2 policy 6
encryption aes-256 aes-192 aes 3des des
integrity sha md5
group 5 2 1
prf sha
crypto ikev2 policy 7
encryption aes-256
integrity sha256
group 14
prf sha256
crypto ikev2 policy 8
encryption aes-256
integrity sha256
group 14
prf sha256
lifetime seconds 28800
crypto ikev2 policy 9
encryption aes-gcm-256 aes-gcm-192 aes-gcm
integrity null
group 2
prf sha256
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 50
encryption aes
integrity sha256
group 19
prf sha256
lifetime seconds 14400
crypto ikev2 policy 60
encryption aes-256
integrity sha384
group 5
prf sha384
crypto ikev2 enable outside client-services port 443
crypto ikev2 enable rdspppoe client-services port 443
crypto ikev2 remote-access trustpoint ASDM_TrustPoint1
crypto ikev1 enable outside
crypto ikev1 enable rdspppoe
crypto ikev1 policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 160
encryption aes-256
hash sha
group 5
lifetime 86400
crypto ikev1 policy 200
encryption aes
hash sha
group 2
lifetime 28800
crypto ikev1 policy 202
encryption aes
hash sha
group 5
lifetime 86400
crypto ikev1 policy 210
encryption aes
hash sha
group 5
lifetime 28800
track 1 rtr 1 reachability
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 50
ssh version 2
ssh key-exchange group dh-group14-sha1
console timeout 0
management-access inside
no ipv6-vpn-addr-assign aaa
no ipv6-vpn-addr-assign local
dhcp-client client-id interface outside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd option 3 ip 192.168.1.1 interface management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl trust-point ASDM_TrustPoint1 outside
ssl trust-point ASDM_TrustPoint1 inside
ssl trust-point ASDM_TrustPoint1 cisco6500
ssl trust-point ASDM_TrustPoint1 rdspppoe
webvpn
enable outside
enable rdspppoe
hsts
  enable
  max-age 31536000
  include-sub-domains
  no preload
anyconnect image disk0:/anyconnect-macos-4.7.01076-webdeploy-k9.pkg 3
anyconnect image disk0:/anyconnect-win-4.7.01076-webdeploy-k9.pkg 4
anyconnect profiles vpc_city_client_profile disk0:/vpc_city_client_profile.xml
anyconnect enable
tunnel-group-list enable
cache
  disable
error-recovery disable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
group-policy GroupPolicy_94.203.254.169 internal
group-policy GroupPolicy_94.203.254.169 attributes
group-policy GroupPolicy_vps-city1 internal
group-policy GroupPolicy_vps-city1 attributes
wins-server none
dns-server value 8.8.8.8 8.8.4.4
vpn-tunnel-protocol ikev2 ssl-client
split-tunnel-policy tunnelall
default-domain none
split-tunnel-all-dns enable
webvpn
  anyconnect mtu 1354
  anyconnect profiles value vpc_city_client_profile type user
group-policy toxx-l2tp internal
group-policy toxx-l2tp attributes
vpn-tunnel-protocol l2tp-ipsec
dynamic-access-policy-record DfltAccessPolicy
webvpn
  svc ask enable default webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map type inspect esmtp esmtp_pmap
parameters
  no mask-banner
  allow-tls
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect sip
  inspect icmp
  inspect ipsec-pass-thru
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:c58401d194d0d29ecc77f853c8e4eaa0
: end
I don't see a split tunnel access list anywhere for your inside network. You need to add the below and apply it to your respective group policies:
Asa-VPN(config)# access-list Split-Tunnel standard permit 10.10.1.0 255.255.255.0
Asa-VPN(config)# group-policy toxx-l2tp attributes
Asa-VPN(config-group-policy)# split-tunnel-policy tunnelspecified
Asa-VPN(config-group-policy)# split-tunnel-network-list value Split-Tunnel
Asa-VPN(config)# group-policy GroupPolicy_vps-city1 attributes
please correct me if i am wrong but the split tunnel i would use it to allow remote vpn users to their respective local networks.
so that will not help with the hosts on my inside network.
regards
alex
my bad, I misread your post. What do you have in your routing table ? Try and disable the NAT entry below. You basically NAT your inside network to both interfaces, try to use just one at a time:
or use after auto NAT for one of the NAT entries:
nat (inside,rdspppoe) after-auto source dynamic any interface
