Cisco ASA switch 3560 lay 3 windows DHCP VLAN and no internet
phugiay
Hi all,
I am new in Cisco and I set up a lab work network with servers, DHCP, DNS, VLAN ASA 5505 and a switch 3560(not sure this is  lay 3 switch).
I want the switch to get IP addresses from Windows server.DHCP with 1/2 is  VLAN 10 and 1/2 is VLAN12.
The windows server DHCP is on VLAN 10. I attached my configuration files below
1. I can make the ASA connecting to switch.
From switch, I can ping ASA, servers, laptop, internet like yahoo so the same as from ASA.
However, from laptop, I can ping the servers, ASA(192.168.10.5 port connect to switch), switch ( VLAN 10,192.168.10.8, port connect to ASA) but there is no internet.
If I enable dhcp like below from switch or ASA, the laptops will get the internet but still not for the servers (because the servers get the static IP address?)
dhcpd address 192.168.10.100-192.168.10.00 PHAM
dhcpd dns 8.8.8.8 interface PHAM
dhcpd enable PHAM
2. Last, I am not sure I have lay 3 but it is Cisco 3560 because I have a problem to make VLAN 10 and VLAN12 talk
3. Here is my result
From switch
vp-sw1#ping 192.168.10.5
Sending 5, 100-byte ICMP Echos to 192.168.10.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/7/34 ms
vp-sw1#ping 192.168.10.8
Sending 5, 100-byte ICMP Echos to 192.168.10.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
vp-sw1#ping 192.168.10.110
Sending 5, 100-byte ICMP Echos to 192.168.10.110, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
vp-sw1#ping 10.0.0.234
Sending 5, 100-byte ICMP Echos to 10.0.0.234, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/9 ms
vp-sw1#ping 10.0.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
calithera-sw1#
vp-sw1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.10.5 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, Vlan10
S* 0.0.0.0/0 [1/0] via 192.168.10.5
From ASA
ciscoasa# ping 192.168.10.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ciscoasa# ping 192.168.10.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/32/90 ms
ciscoasa# ping 192.168.10.110
ciscoasa# ping 192.168.10.126
Sending 5, 100-byte ICMP Echos to 192.168.10.126, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
ciscoasa# ping 192.168.10.10
Sending 5, 100-byte ICMP Echos to 192.168.10.10, timeout is 2 seconds:
ciscoasa# ping 157.240.22.35
Sending 5, 100-byte ICMP Echos to 157.240.22.35, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 10/12/20 ms
ciscoasa#
Thank you very much.
3 Accepted Solutions
HI MHM,
Thank you for your help. I almost get there. Still have a problem with two VLANs talk each other if I use Windows DHCP.
are the dhcp send default-router
as the IP of Inside interface of ASA
or as the IP of SVI of vlan ?
phugiay
Actually I finally figure it out. It is route issue from ASA and switch lay 3. My project is completed Thank you all for your help.
24 Replies 24
phugiay
Any suggestion?
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
and the outside already have setroute,
you need to remove
static route
since the
next-hop
is change (dhcp)
Hi MHM,
Thank you very much. I removed the
 static route
and it shows connected but
From the ASA, switch, servers or laptops, I cannot ping the website like yahoo.com or facebook and cannot browse to their website but I can ping their IP address and can browse with the IP address without any issue.
I look on Google and people said most is the DNS or DMZ issue.
Any advise?
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
I am not so sure, but I this xlate deny is the issue it must permit,
can you try make it permit ?
note:- I will run lab test your config.
Hi MHM,
Thanks I clear configure xlate and permit them all but I still cannot ping yahoo.com from ASA but I can ping their IP 74.6.143.25. Same as switch or PCs.
If I enable and use DHCP from ASA, I can browser internet from PCs but still not ping from yahoo.com from ASA .Something tell me there is blocking from ASA.
first please return the config of xlate, I check and it by default deny, so no need to be permit.
interface Vlan1
 nameif inside
interface Vlan10
 nameif PHAM
interface Vlan15
 nameif VPHAM
you have three interface
inside ,this have dynamic NAT with overload no dhcp
PHAM , have dynamic NAT with overload no dhcp
VPHAM not have dynamic NAT with overload and there is DHCP.
which one you face issue with it??
I will run the config of xlate tonight. The one I have a problem is Inside when I use Windows DHCP. I want to check what cause the ASA cannot ping google.com or yahoo.com but I can ping 8.8.8.8. When I enable DHCP from VPHAM on ASA for test, I can browser or ping yahoo.com google.com but I don't want to use DHCP from ASA.
Thank you
I run lab and dont see any issue,
can you check ASA
 packet-tracer
packet-tracer input <intrerface inside or PHAM or VPHAM> udp <ip from subnet of inside or PHAN or VPHAM> 12345 <8.8.8.8> 53
 Hi MHM,
Here is my packet-tracer
ciscoasa# packet-tracer input inside udp 192.168.10.5 12345 8.8.8.8 53
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in 0.0.0.0 0.0.0.0 outside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ciscoasa# packet-tracer input inside udp 192.168.10.5 12345 8.8.8.8 53 detail
<<- sorry add this to make us know why ACL drop traffic
interface Vlan1
 nameif inside
 security-level 100
 ip address 10.33.20.3 255.255.255.0
192.168.10.5 <<- why you sue this subnet it not same subnet connect to inside interface ?
Hi MHM,
Thank you. Actually changed the IP for inside to 192.168.10.5 but I put it back to 10.33.20.3. I found the issue. I accidently remove the
dns domain-lookup outside
and I put it back and add the dns  and now I can ping the yahoo.com or facebook from ASA. I can ping yahoo.com /browser from switch and server and PCs.
dns name-server 8.8.8.8.
If I use DHCP from switch 3560 layer 3 for VLAN 10 and 12 and issue ip routing, both VLAN can see each other. From PC 1 VLAN 10 I can ping PC 2 on VLAN 12 and also from  PC2 on VLAN12  and I can ping PC1 and the both have internet.
However, if I remove DHCP server from switch and use Windows DHCP with two NICs, VLAN 10 (192.168.10...) and 12 (10.33.12.0) cannot see each other and VLAN12has internet but VLAN 10 is not. From the switch, I can ping website, all PCS and servers.
I thought layer 3 switch, we can use ip routing so all VLANS can see each other or I need a router.
Thank you
you are so so welcome,
glad the issue is solved.
good luck friend.
HI MHM,
