Cisco asa5505 as router + vpn ipsec + dhcp server
Greg Maaaag
Hello!
We've got cisco881w and now it reached it's brandwidth and we decided to change it to asa5505
I've never configured such devices and I got used to iOS and it's very difficult to get used to it's syntaxes
Config of 811 here:
version 15.1
no service pad
service password-encryption
hostname Voznes
boot-start-marker
boot-end-marker
enable secret 5 *
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp excluded-address 192.168.200.1 192.168.200.100
ip dhcp pool pool
network 192.168.200.0 255.255.255.0
default-router 192.168.200.12
dns-server 192.168.240.100 82.112.184.34 82.112.185.35
ip cef
no ip domain lookup
ip domain name office
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn *
username b1_adm privilege 15 secret 5 *
username 1line privilege 15 secret 5 *
ip tcp synwait-time 5
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key 6 * address 89.223.6.92
crypto ipsec transform-set myset esp-aes esp-md5-hmac
crypto map vpn 80 ipsec-isakmp
set peer 89.223.6.92
set transform-set myset
match address 102
interface Loopback0
no ip address
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 89.104.102.226 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map vpn
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.254.99 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.200.12 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.200.5 80 89.104.102.226 80 extendable
ip nat inside source static tcp 192.168.200.5 443 89.104.102.226 443 extendable
ip nat inside source static tcp 192.168.200.5 22 89.104.102.226 2222 route-map internal extendable
ip nat inside source static tcp 192.168.200.5 5060 89.104.102.226 5060 extendable
ip nat inside source static tcp 192.168.200.112 7000 89.104.102.226 7000 route-map internal extendable
ip nat inside source static tcp 192.168.200.110 7000 89.104.102.226 7001 route-map internal extendable
ip route 0.0.0.0 0.0.0.0 89.104.102.225
logging esm config
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 100 deny   ip 192.168.200.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 100 permit ip 192.168.200.0 0.0.0.255 any
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 102 permit ip 192.168.200.0 0.0.0.255 192.168.240.0 0.0.0.255
route-map vpn permit 10
match ip address 102
set interface FastEthernet4
snmp-server community mon_cacti RO
line con 0
exec-timeout 30 30
privilege level 15
password 7 *
logging synchronous
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
privilege level 15
password 7 *
login local
transport input all
end
On 5505 i've made:
ASA Version 9.1(1)
hostname Voznes
enable password 8Ry2YjIyt7RRXU24 encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.200.13 255.255.255.0
interface Vlan2
nameif outside
security-level 0
boot system disk0:/asa911-k8.bin
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-702.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 89.104.102.225 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 192.168.240.100
dhcpd address 192.168.200.100-192.168.200.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username b1_adm password wDZk1nEY6hhCN82f encrypted
prompt hostname context
call-home reporting anonymous
Cryptochecksum:e4240d63a2219e017830f7d48c454d20
: end
But DHCP doesn't work, I'm totally desperated:( What'm doing wrong, help me please!
olivergw1
I believe you are missing the configuration to allow access to your routed VLAN interface. So to use port 'Ethernet 0/0' do the following
Conf t
Interface Ethernet 0/0
switchport access vlan 1
This will turn that port into a switch port and allow access to VLAN 1 which is the interface you have configured a DHCP pool for.
Ollie
pope30349
Vlan 1 is the default so right now everything is in vlan 1, even your outside interface. You need:
Conf t
Switchport access vlan 2
This will put Ethernet 0/0 in vlan 2 on the outside. Right now you have it on the inside. Also this is the Internet connection so this is the port the go's to your ISP.
thank you for the answer!
i'w deleted vlan on eth 0/0 because i was testing dhcp.
When i connect to any ethernet interface my notebook can't obtaion IP address. If i use static i can ping asa's vlan 1 ip address but dhcp insn't working
P.S. does any one compared using like router asa 5505 or 1921, what's the difference?
