CISCO ASAv can not ping between subnets
Alex.kushnarev
Hi team,
i am using ASAv version 9.12.2 on AWS and i have few internal interfaces (security level 100) and i can not get them to ping each other even when. i am running the same-security lever permit command. i have tried to create an ACL to permit traffic from anywhere to anywhere with no success and i have few pre-made ACLs that i could not delete.
here is my conf:
: Saved
: Serial Number: 9AS6FC2VFFG
: Hardware:   ASAv, 7680 MB RAM, CPU Xeon E5 series 2900 MHz, 1 CPU (4 cores)
ASA Version 9.12(2)
hostname ciscoasa
enable password ***** pbkdf2
names
no mac-address auto
interface GigabitEthernet0/0
nameif App
security-level 100
ip address dhcp setroute
interface GigabitEthernet0/1
nameif Web
security-level 100
interface GigabitEthernet0/2
nameif Guest
security-level 100
interface Management0/0
management-only
nameif mgmt
security-level 90
ftp mode passive
clock timezone IST 2
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network App
host 10.0.200.0
object network Web
subnet 10.0.100.0 255.255.255.0
access-list App_access_in extended permit ip any any
access-list Web_access_in extended permit ip any any
access-list Guest_access_in extended permit ip any any
pager lines 23
logging enable
logging trap debugging
logging asdm notifications
logging host mgmt 10.0.250.44 6/1470
mtu mgmt 1500
mtu App 1500
mtu Web 1500
mtu Guest 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
object network App
nat (any,App) dynamic interface
object network Web
nat (any,Web) dynamic interface
access-group App_access_in in interface App
access-group Web_access_in in interface Web
access-group Guest_access_in in interface Guest
router ospf 100
network 10.0.100.0 255.255.255.0 area 0
network 10.0.200.0 255.255.255.0 area 0
network 0.0.0.0 0.0.0.0 area 0
log-adj-changes
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 10.0.250.0 255.255.255.0 App
http 10.0.250.0 255.255.255.0 mgmt
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
auto-import
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 0509###
  quit
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 mgmt
ssh timeout 30
ssh version 1 2
console timeout 0
vpn load-balancing
dhcp-client client-id interface App
dhcp-client client-id interface Web
dhcp-client client-id interface Guest
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
username admin nopassword privilege 15
username admin attributes
service-type admin
ssh authentication publickey ## hashed
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
class inspection_default
  inspect ip-options
  inspect netbios
  inspect rtsp
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
policy-map type inspect dns migrated_dns_map_2
parameters
  no tcp-inspection
policy-map type inspect dns migrated_dns_map_1
parameters
  no tcp-inspection
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile License
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination transport-method http
profile CiscoTAC-1
  no active
  destination address email callhome@cisco.com
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:e7da6c4626b216ca9493ffa5e6e509c4
: end
can any one tell me what am i missing here?
Best Regards,
Alex.
17 Replies 17
Hi i still get destination host unreachable
this is the current running conf :
: Saved
ASA Version 9.12(2)
hostname ciscoasa
names
no mac-address auto
nameif App
security-level 100
ip address 10.0.100.240 255.255.255.0
nameif Web
security-level 50
ip address 10.0.200.240 255.255.255.0
nameif Guest
security-level 0
ip address 10.0.150.240 255.255.255.0
management-only
nameif mgmt
security-level 90
ftp mode passive
object network App_Web
object network Web_App
subnet 10.0.200.0 255.255.255.0
pager lines 23
logging enable
logging timestamp
mtu App 1500
mtu Web 1500
mtu Guest 1500
mtu mgmt 1500
no failover
no monitor-interface service-module
arp timeout 14400
nat (App,Web) static 10.0.200.0
nat (Web,App) static 10.0.100.0
router eigrp 10
network 10.0.150.0 255.255.255.0
http server enable
no validation-usage
crl configure
auto-import
certificate ca 0509
  quit
telnet timeout 5
ssh timeout 30
ssh version 1 2
console timeout 0
vpn load-balancing
service-type admin
ssh authentication publickey ####f:24:b8 hashed
parameters
  no tcp-inspection
  inspect ip-options
  inspect netbios
  inspect rtsp
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
parameters
  no tcp-inspection
parameters
  no tcp-inspection
call-home
profile CiscoTAC-1
  no active
profile License
Cryptochecksum:1ead1ba70c712715a1f115a0874b787f
: end
Hello
I dont see an access-group for the access-lists
access-group App_access_in in interface Web
access-group Web_access_in in interface App
Kind Regards
Paul
Hi @paul driver,
i have added the access-groups and still getting destination host unreachable.
: Saved
ASA Version 9.12(2)
hostname ciscoasa
names
no mac-address auto
nameif App
security-level 100
nameif Web
security-level 50
nameif Guest
security-level 0
management-only
nameif mgmt
security-level 90
ftp mode passive
pager lines 23
logging enable
logging timestamp
mtu App 1500
mtu Web 1500
mtu Guest 1500
mtu mgmt 1500
no failover
arp timeout 14400
router eigrp 10
http server enable
no validation-usage
crl configure
auto-import
certificate ca 0509
  quit
telnet timeout 5
ssh timeout 30
ssh version 1 2
console timeout 0
vpn load-balancing
service-type admin
hashed
parameters
  no tcp-inspection
  inspect ip-options
  inspect netbios
  inspect rtsp
  inspect sunrpc
  inspect tftp
  inspect xdmcp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect sip
  inspect skinny
parameters
  no tcp-inspection
parameters
  no tcp-inspection
call-home
profile CiscoTAC-1
  no active
profile License
Cryptochecksum:##
: end
