Cisco ASR 1006
cgarcia1971
How to configure the IP flow for this device: Cisco ASR 1006; IOS ver: 03.16.02b.S., which does not support the following command below:
The old Cisco Device having this configuration:
ip flow-export version 5
ip flow-export destination 192.168.207.89 9996
interface Serial4/1:1
description Connection to KHAMIS
bandwidth 512
ip address 172.16.40.6 255.255.255.252
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation ppp
snmp trap ip verify drop-rate
ntp disable
Thanks and Best Regards,
Carlos Garcia
Hello Carlos,
the traditional NetFlow is not available on the ASR1000 in releases later than 3.10. Cisco recommends to use Flexible NetFlow:
End-of-Sale and End-of-Life of the Cisco Traditional NetFlow Feature
Cisco announces the end-of-sale and end-of-life of the Cisco Traditional NetFlow (TNF) Feature on the Cisco ASR1000 platform. Cisco will not have any future development, CLI support, TAC support, and documentation pertaining to the Cisco TNF feature beyond Cisco IOS XE Software Release 3.10.
Customers with the Cisco TNF feature on the Cisco ASR1000 platform are encouraged to migrate to the Cisco Flexible NetFlow (FNF) feature on the Cisco ASR1000 platform.
For details on transition to Cisco FNF, see the Migrating from Traditional to Flexible NetFlow white paper:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/ps6965/white_paper_c11-545581.html
Thanks man, I will try this one and let you know.
