Cisco ASR Port Gi0
sanjay.khurana
we have cisco ASA router 1004 , router have one inbuilt port Gi0 .. which is for management , can we use this interface for normal routing purpose.
if some one tried let us know.
R/
Sanjay
Rahul Kukreja
You may check the following URL's for your query -
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/Management_Ethernet.html#wp1058875
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/qa_c67-443169.html
Q. Are routing protocols supported on the 10/100/1000BASE-T management interface?
A. Yes, routing protocols are supported on the management interface. However, the management interface is strictly for management purposes only, with limited packet forwarding.
This interface is not meant for normal packet forwarding.
- HTH
Rahul
