ISP router filtering traffic
Raha_1990
Hi!could you explain the correct answer in the question shown?
regards,Abdurahman
5 Replies 5
Abzal
Level 7
Level 7
I think the correct answer is the last one.
1. First, because ACL applied to subnet /21 not to host 64.100.0.1.
2. Second, ACL effects to with source subnet /21 only not any source.
3. Third, as second.
4. Fourth, ACL 101 as per first statement it is denied.
5. So only fifth option.
Hope it will help.
Best regards,
Abzal
no,it's not correct
Rahul Kukreja
The correct answer should be 4th option.
All traffic from 64.100.0.0/21 network could access internet.
It's because -
When the traffic from RTR goes out to ISP the source address will always be in the range of 64.100.0.0/21 - which is permitted in ACL 1 applied in the inbound on ser0/0/0 of ISP. So as the ACL 1 checks only the source ip it is permitted.
For the return traffic from the Internet the source ip could be ANY and the destination would be always 64.100.0.0/21 which is permitted in the ACL 101 applied in the outbound on ser0/0/0
- HTH
Rahul
but in ACL 101 it is denied.how to understand that we must follow ACL 1,not ACL 101?
ACL 1 will be checked for the traffic coming in on ser0/0/0
ACL's in IOS are checked from top to bottom, and as in ACL 1 traffic from 64.100.0.0/21 is permitted traffic gets routed to Internet when it comes from RTR Router.
For the return traffic, the ACL 101 is checked when the traffic leaves out from ser0/0/0 and here in the ACL 101 when it is checked from top to bottom -
access-list 101 deny ip 64.100.0.0 0.0.7.255 any
access-list 101 permit ip any 64.100.0.0 0.0.7.255
So the return traffic going out via seril0/0/0 on ISP Router will never match the first deny statement in ACL 101 (because the return traffic will never have the source ip as 64.100.0.0/21) - it matches the second permit statement and traffic is sent out via ser0/0/0
Thus for the traffic to Internet - both the ACLs are checked.
- HTH
Rahul
