Cisco ASR Router IOS XE Upgrade to 3.4.x
yogesh rajguru
Hi All,
Wanted help regarding the Cisco ASR Router IOS XE Upgrade.
We are having Cisco ASR 1006 Router with the XE Code :asr1000rp1_advance entrprisek9.03.01.00.S.150_1.S.bin
The basic information we are having is
cisco ASR1006 (RP1) processor with 1717513K/6147K bytes of memory.
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
937983K bytes of eUSB flash at bootflash:.
39004543K bytes of SATA hard disk at harddisk:.
Wanted to upgrade to the latest IOS XE 3.4.x but the memory requirement for this IOS is Dram 4GB. But the DRAM actually is 2GB as per show version command.
Here the Physical memory is showing 4 GB so can we upgrade this IOS XE?
yogesh rajguru
Just out of BOX i am thinking, is it the case, as we are using 2 RP1 and the 2GB of DRAM + 2GB of DRAM i.e. 4GB Dram, its showing as a Physical Memory?
Because if I check "sh process memory" there also its showing 2GB of Memory used.
------------------ show process memory ------------------
Processor Pool Total: 1758647744 Used:  299906788 Free: 1458740956
lsmpi_io Pool Total:    6295088 Used:    6294116 Free:        972
Yogesh.
Can you please confirm to me is the below steps  is the right steps to upgrade ASR 1002&1006
and why we need to add /auto/tftp-users/user why not the IOS only as like normal upgrade for 6500 series
/auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router# dir bootflash:
Directory of bootflash:/
11 drwx 16384 Dec 4 2007 04:32:46 -08:00 lost+found
86401 drwx 4096 Dec 4 2007 06:06:24 -08:00 .ssh
14401 drwx 4096 Dec 4 2007 06:06:36 -08:00 .rollback_timer
28801 drwx 4096 Mar 18 2008 17:31:17 -07:00 .prst_sync
43201 drwx 4096 Dec 4 2007 04:34:45 -08:00 .installer
13 -rw- 45977 Apr 9 2008 16:48:46 -07:00 target_support_output.tgz.tgz
928862208 bytes total (712273920 bytes free)
Router# copy tftp bootflash:
Address or name of remote host []? 172.17.16.81
Source filename []?
Destination filename [asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin]?
Accessing
tftp://172.17.16.81//auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bIN
Loading /auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin from
172.17.16.81 (via GigabitEthernet0):
[OK - 208904396 bytes]
208904396 bytes copied in 330.453 secs (632176 bytes/sec)
12 -rw- 208904396 May 28 2008 16:17:34 -07:00
928862208 bytes total (503156736 bytes free)
Router# config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#boot system flash
bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router(config)#config-reg 0x2102
Router(config)#exit
Router#show run | include boot
boot-start-marker
boot system flash bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
boot-end-marker
Router# copy run start
Destination filename [startup-config]?
Building configuration...
[OK]
Router# reload
Copy the IOS into the ASR's bootflash.
