ip natting on router
techguy
Level 4
Level 4
Hi all,
I have configured ADSL on my Cisco 1841 router. Intern is working fine. But as i give the below command on router, i lose my telnet connectivity via public ip address. Any clue?
ip nat inside source list 1 interface dialer 1 overload
6 Replies 6
Jeff Van Houten
Level 5
Level 5
Have you configured access-list 1?
yes
Can you give us more detail of how the router is configured? In particular does access list contain a permit any statement? I have seen situations where it seems that address translation with a list with permit any does impact telnet access on the public interface. If your access list 1 does contain permit any then I suggest that you re-write the access list so that it does not permit any.
Rick
Rick
yes i have following command
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
please check if there is any access list under the vty lines.
I suggest that you re-write access list 1 and instead of permit any that you make it permit
Rick
Rick
