Cisco ASR1001 unresponsive on console
NathanB1321
Hi all
I have a Cisco ASR1001 v03 that is not returning anything on console. I have tested the cable with another device and can confirm all operational. The ASR has started but the STAT light is flashing suggesting it hasn't booted I think? Critical light is also solid.
Any help would be greatly appreciated!
Thank you
is the internal hard drive LED (labeled as DISK HD) flashing green ?  Can you even get to the rommon prompt (press the BREAK key during startup) ?
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr-1000-series-hig/asr-hig-tbl.html
Thanks for commenting!
I have not opened up the chassis yet but will check this today. Can you elaborate on how to use the break key?
Thanks again
