Cisco ASR1002 question
david.tran
Level 4
Level 4
I haver a two cisco router ASR 1002-ESP5 connect to a Catalyst 6509-E (layer-2) only and I am going to setup a single GRE tunnel between these two ASR routers and I going to test the throughput over the GRE tunnel between two linux servers 10Gig interfaces, one on each side of the ASR routers, using Iperf with 1400k and 64k size packet, TCP and UDP
the question I have is what will be the "expected" throughput for the ASR with GRE tunnel.  ASR code is version 3.4.1
rtr-server#sh inventory
NAME: "Chassis", DESCR: "Cisco ASR1002 Chassis"
PID: ASR1002           , VID: V04, SN: FOX1413G8ZY
NAME: "module F0", DESCR: "Cisco ASR1000 Embedded Services Processor, 5Gbps"
PID: ASR1000-ESP5      , VID: V03, SN: JAE14350454
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V02, SN: ART1437U01Z
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V02, SN: ART1437U02P
NAME: "module 0", DESCR: "Cisco ASR1002 SPA Interface Processor 10"
PID: ASR1002-SIP10     , VID: V04, SN: JAE14190G52
NAME: "SPA subslot 0/1", DESCR: "1-port OC3/STM1 ATM Shared Port Adapter"
PID: SPA-1XOC3-ATM-V2  , VID: V01, SN: JP6142200DM
NAME: "SPA subslot 0/2", DESCR: "2-port OC3/STM1 POS Shared Port Adapter"
PID: SPA-2XOC3-POS     , VID: V01, SN: JAE14350R66
NAME: "SPA subslot 0/0", DESCR: "4-port Gigabit Ethernet Shared Port Adapter"
PID: 4XGE-BUILT-IN     , VID: V00, SN: N/A
NAME: "subslot 0/0 transceiver 0", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC15240KGR
NAME: "subslot 0/0 transceiver 1", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC16180482
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC161802S5
NAME: "module R0", DESCR: "Cisco ASR1002 Route Processor 1"
PID: ASR1002-RP1       , VID: V04, SN: JAE14190SV9
rtr-server#
0 Replies 0
