Cisco backup link disabled not working !!
andihoxha799
Hello can someone help me I have a problem with Cisco router c7200 I'm trying to make a backup link between two routers but for some reason when I disable the main interface the backup interface doesn't turn on it says disabled, here is my config:
R1#sh run
Building configuration...
Current configuration : 1873 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
--More--
*May 3 00:22:32.011: %SYS-5-CONFIG_I: Configured from console by console
R1#sh run
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
ip tcp synwait-time 5
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip address 10.10.14.1 255.255.255.0
shutdown
duplex full
speed 1000
media-type gbic
negotiation auto
interface GigabitEthernet1/0
no ip address
shutdown
negotiation auto
interface Serial2/0
backup interface GigabitEthernet0/0
ip address 10.10.12.1 255.255.255.0
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial2/4
no ip address
shutdown
interface Serial2/5
no ip address
shutdown
interface Serial2/6
no ip address
shutdown
interface Serial2/7
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#sh run
Current configuration : 1853 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
hidekeys
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no ip address
shutdown
duplex auto
ip address 10.10.14.2 255.255.255.0
duplex full
speed 1000
media-type gbic
negotiation auto
no ip address
shutdown
negotiation auto
interface Serial2/0
ip address 10.10.12.2 255.255.255.0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface Serial2/4
no ip address
shutdown
interface Serial2/5
no ip address
shutdown
interface Serial2/6
no ip address
shutdown
interface Serial2/7
no ip address
shutdown
router ospf 1
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
Testing the backup interface is a little more difficult. A simple shutdown of the interface will not cause the IOS software to see this as a link failure. To test the backup interface, you must physically remove the cable from the serial interface.
so to test backup you must select the link and delete it.
8 Replies 8
andihoxha799
 If this is a simulator, it might be a failure on the simulator.
https://www.youtube.com/watch?v=8dRuzzecToA
This video is pretty clear on how this feature works.
I did this but when I shut the primary interface it doesn't enable the backup interface therefore I can't ping the other router from the backup interface.
Why both interface shutdown' In one router
It must be no shut
Right this makes more sense I understand now, thanks for the explanation.
This is what happens when i shut the primary interface down it dosen't activate the backup interface
Hello
Looks like you are trying t use flex-link, as such the backup interfaces need to be administratively enabled
int x.x
backup xxx
no shut
Kind Regards
Paul
