cisco best practice for load balancing HSRP
enzo80
What's the best way to do load balancing nowadays with HSRP
8 Replies 8
Mark Elsen
  - FYI : https://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/13781-7.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
@balaji.bandi Where is the load balancing configuration in that document ? I only see basic HSRP for redundancy...
Hope OP Looking "cisco best practice for load balancing HSRP"
~Not the configuration here..... that documen give user enough understanding..(my views)
BB
the easiest would be to have both routers configured as active, by using two HSRP groups, and splitting the clients.
Have a look at the configuration example below:
https://flylib.com/books/en/2.286.1/load_balancing_with_hsrp.html
Hello
I personally would say the easiest solution in any first hop redundancy protocols for load balancing would be to use GLBP as that’s what it is designed to do.
Kind Regards
Paul
Joseph W. Doherty
As @paul driver already suggested, for "best" FHRP load balancing, you might consider using GLBP.
I haven't reviewed the links provided by the other posters, but usually, in older variants of HSRP you might alternate which router was primary for different network gateways.  The latter variants of HSRP are a bit more flexible in that you can have multiple primary (but different) primary HSRP addresses within the same network.
However, keep in mind, none of these variants dynamically load balance, so it's, for example, possible one extremely busy host will "congest" a FHRP gateway while the other is under utilized.  It's possible, though to manually manage this in some of the foregoing too, but that's also a bit of a management headache.
enzo80
thanks all for the help, I guess we will use GLBP instead since it easier to setup
