Cisco C1111-4P
fpaulnsteiner
We also use the router for bandwidth measurement before we hand over the service to our customer. We do this with
udp-small-services to echo the udp measurement traffic.
This works with this Routertype up to 35Mb/s,  higher bandwidths cause a 100% cpu load.
Alternatively, a Cisco 892 Router will provide 100 Mb/s in such a scenario.
Does anyone have any experience or an idea why a state of the art Router is moderately overwhelmed in cpu by this scenario?
5 Replies 5
balaji.bandi
we like to know is your configuration, what causing the CPU high load?
these model sure need to give you more performance, but it was not, so we need to look in what causing this issue.
post below output.
show version
show  process cpu sorted
show run
BB
Hello BB!
Cisco-1111#sh proc cpu sorted | e 0.00%
CPU utilization for five seconds: 79%/46%; one minute: 73%; five minutes: 39%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
508 67684 518849 130 32.87% 30.02% 15.80% 0 UDP Echo
121 765632 5935994 128 14.00% 14.36% 7.78% 0 IOSXE-RP Punt Se
9 2942648 650357 4524 0.47% 0.10% 0.06% 0 Check heaps
Cisco-1111#
Cisco-1111# sh interface GigabitEthernet0/0/0
...omitted
30 second input rate 39657000 bits/sec, 3552 packets/sec
30 second output rate 32315000 bits/sec, 2888 packets/sec
...omitted
Cisco-1111#sh version
...omitted
System image file is "bootflash:c1100-universalk9_ias.16.06.04.SPA.bin"
...omitted
Cisco-1111#sh run
Building configuration...
version 16.6
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service udp-small-servers
service sequence-numbers
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Cisco-1111#
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone MEZ 1 0
clock summer-time MESZ recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
no ip bootp server
no ip domain lookup
ip domain name a1.net
login on-success log
subscriber templating
vtp mode transparent
vlan internal allocation policy ascending
no cdp run
description *** Provider WAN Interface ***
bandwidth 40000
ip address x.x.x.x 255.255.255.252
no ip redirects
no ip proxy-arp
load-interval 30
media-type rj45
negotiation auto
no cdp enable
interface GigabitEthernet0/0/1
description *** Customer LAN Interface ***
ip address x.x.x.x 255.255.255.240
no ip redirects
no ip proxy-arp
negotiation auto
no cdp enable
interface GigabitEthernet0/1/0
shutdown
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
shutdown
interface GigabitEthernet0/1/3
shutdown
interface GigabitEthernet0/1/4
shutdown
interface GigabitEthernet0/1/5
shutdown
interface GigabitEthernet0/1/6
shutdown
interface GigabitEthernet0/1/7
shutdown
interface Vlan1
no ip address
...omitted
Cisco-1111#
interesting logg during test:
000683: May 24 08:00:14.124 MESZ: %IOSXE-5-PLATFORM: R0/0: cpp_cp: QFP:0.0 Thread:000 TS:00004561030145814691 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 11
I have tested with command configured:
its the same cause.
It looks like there is a build in cpp!
best regards
Hello fpaulnsteiner,
if there is an auto CoPP applied on the device this can also influence the results of your performance test.
UDP traffic may be rate limited at some point.
Even if I agree that the UDP echo process looks like to use a lot of CPU
see CoPP best practices
https://www.cisco.com/c/en/us/about/security-center/copp-best-practices.html
Hope to help
Giuseppe
adding to other comment, worth looking this bug also :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj62552/?rfs=iqvred
BB
Hello BB, sorry for the delay!
The root cause for this problem seems to be the punt-policer, ( COPP is not configured) but when i disable it, there is no difference in the bandwith measurement.
Cisco-1111(config)# platform punt-policer 11 ?
  <10-64600>  max punt rate for cause For-us data
  alerting    Enable punt-policer's notification
Cisco-1111(config)# platform punt-policer 11 64600 ?
  <1-226100>  max burst size for cause For-us data
  high        High priority traffic only
  <cr>
Cisco-1111(config)#no platform punt-policer 11 64600 226100
"%PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 11"
Does anyone have an idea how to really switch off the punt policer?
Best regards
