CISCO C1111-8P Configuration help
SDES
Hi All,
I am a Cisco novice need help setting up my Cisco C1111-8P ISR.
I got Virgin Media hub 3 setup in the modem mode (due to my sons constant nags of high latency when playing games while hub 3 in router mode).
Need to setup C1111-8P to issue DHCP addresses 192.168.0.xxx and like to use maximum LAN ports as possible (can see two WAN ports and like to use one for internal LAN if possible). Device capable of POE and like to power my wireless access point form ISR.
Any help including a pre made configuration much appreciated.
Thank you.
 You can have up 4 to ports out of 8 with PoE. You cant have all 8 ports with PoE due Power supply capacity.
Wan ports does not work as Lan port.
And for dhcp Server configuration, you can follow this guide. It is simple.
https://ultraconfig.com.au/blog/dhcp-server-configuration-on-a-cisco-isr-router-running-ios-xe/
SDES
Thank you Flavio for taking time to help
I will give it a try.
