HSRP standby router is unknow
hnavi77
Hello Team,
I am trying to figure out why my active HSRP router is not seeing the standby router (standby router is unknow).
D11(config)#do sh standby bri
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Vl10 0 150 P Active local unknown 10.10.10.254
I went with a very simple design to figure out what is happening.
I am using CML 3.0 with 2 routers (D11 and D12 -> HSRP) and a switch where i do have a desktop connected to it for testing purpose with one Interface vlan 10 on both routers. Switch device is configured with VLAN 10 only.
After debugging IP packet from both HSRP devices, i discovered that the active router (D11) is not receiving multicast IP address from D12. I do not have any ACL configured on any Routers and switches...
Below the configuration:
Active HSRP - Router D11
D11(config)#do sh run int g0/1
Building configuration...
Current configuration : 105 bytes
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
negotiation auto
end
D11(config-if)#do sh run int vlan 10
Current configuration : 150 bytes
interface Vlan10
ip address 10.10.10.1 255.255.255.0
standby version 2
standby 0 ip 10.10.10.254
standby 0 priority 150
standby 0 preempt
end
Standby HSRP - Router D11
D12(config)#do sh run int gi0/1
negotiation auto
end
D12(config)#do sh run int vlan 10
Current configuration : 126 bytes
interface Vlan10
ip address 10.10.10.2 255.255.255.0
standby version 2
standby 0 preempt
end
Switch:
SW1(config)#do sh run int gi0/1
negotiation auto
end
SW1(config)#do sh run int gi0/2
interface GigabitEthernet0/2
negotiation auto
end
Debugging from D11:
D11(config)#$ 100 permit udp host 10.10.10.2 host 224.0.0.102 eq 1985
D11(config)#$ 100 permit udp host 10.10.10.1 host 224.0.0.102 eq 1985
D11(config)#do debug ip pack 100
IP packet debugging is on for access list 100
D11(config)#
*Apr 29 16:38:30.496: IP: s=10.10.10.1 (local), d=224.0.0.102 (Vlan10), len 80, local feature, Auth Proxy(16), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Apr 29 16:38:30.496: IP: s=10.10.10.1 (local), d=224.0.0.102 (Vlan10), len 80, sending broad/multicast
*Apr 29 16:38:30.496: IP: s=10.10.10.1 (local), d=224.0.0.102 (Vlan10), len 80, sending full packet
D11(config)#
Debugging from D12:
D12(config)#do sh run | s access-list
access-list 100 permit udp host 10.10.10.2 host 224.0.0.102 eq 1985
access-list 100 permit udp host 10.10.10.1 host 224.0.0.102 eq 1985
D12(config)#do debug ip pack 100
D12(config)#
*Apr 29 16:38:14.149: IP: s=10.10.10.1 (Vlan10), d=224.0.0.102, len 80, rcvd 0
*Apr 29 16:38:14.150: IP: s=10.10.10.1 (Vlan10), d=224.0.0.102, len 80, input feature, packet consumed, MCI Check(109), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Apr 29 16:38:14.495: IP: s=10.10.10.2 (local), d=224.0.0.102 (Vlan10), len 80, local feature, Auth Proxy(16), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
*Apr 29 16:38:14.496: IP: s=10.10.10.2 (local), d=224.0.0.102 (Vlan10), len 80, sending broad/multicast
*Apr 29 16:38:14.497: IP: s=10.10.10.2 (local), d=224.0.0.102 (Vlan10), len 80, sending full packet
D12(config)#
Thanks for your help, in advance if you can figure out what's going one.
@hnavi77 I have attached the file with the requested output. I have the configuration of all 3 devices on there with separation indicators, and lower down the file I put an alternate port configuration that also works. They all should either be access port or all be trunk ports. It didn't work if access/trunk configuration was used. Please let me know if you have any questions.
D11#sh standby brief
Vl10 0 150 P Active local 10.10.10.2 10.10.10.254
D12#sh standby brief
Vl10 0 100 P Standby 10.10.10.1 local 10.10.10.254
D12#
-David
37 Replies 37
no ip igmp snooping in SW
hnavi77
Applied it in global config of switch but this doesn't fix the problem.
the access list does not look right. Use the one below:
access-list 100 permit udp any host 224.0.0.102 eq 1985
hnavi77
Hello Georg,
My acl = yours:
no ip igmp snooping in all SW
also  check VTP I think the domain is mismatch and this broke the HSRP connection.
show standby <-if both two step not solve issue
hnavi77
I dont have VTP configured at all, do you think this may be the reason?
let me configure it, curious to see the result.
hnavi77
Problem not resolved.
VTP configured on 3 sw:
D11(config-if)#do sh vtp status
VTP Version capable : 1 to 3
VTP version running : 2
VTP Domain Name : test
VTP Pruning Mode : Disabled
VTP Traps Generation : Disabled
Device ID : 5254.0000.8000
Configuration last modified by 10.10.10.1 at 4-29-22 19:01:39
Local updater ID is 10.10.10.1 on interface Vl10 (lowest numbered VLAN interface found)
Feature VLAN:
VTP Operating Mode : Server
Maximum VLANs supported locally : 1005
Number of existing VLANs : 6
Configuration Revision : 2
MD5 digest : 0x11 0x42 0x46 0x66 0xDC 0xD7 0x27 0x38
0x1A 0xCF 0x97 0x0F 0xCF 0x8A 0xE5 0xAF
SW1(config-if)#do sh vtp status
Configuration last modified by 0.0.0.0 at 4-29-22 19:01:16
Local updater ID is 10.10.10.100 on interface Vl10 (lowest numbered VLAN interface found)
Feature VLAN:
MD5 digest : 0x64 0xAA 0x27 0x4A 0x80 0x83 0x48 0xB7
0xE6 0x9A 0x09 0x74 0xBC 0xE8 0x4B 0xA4
D12(config-if)#do sh vtp status
Configuration last modified by 10.10.10.2 at 4-29-22 19:04:51
Local updater ID is 10.10.10.2 on interface Vl10 (lowest numbered VLAN interface found)
Feature VLAN:
MD5 digest : 0x7C 0x28 0x92 0xFE 0xE7 0x8A 0x75 0xED
0x42 0x8F 0xBF 0xBF 0xC6 0xD9 0xD3 0xC4
Standby config - D11:
D11(config-if)#do sh standby
Vlan10 - Group 0 (version 2)
State is Active
12 state changes, last state change 00:03:07
Virtual IP address is 10.10.10.254
Active virtual MAC address is 0000.0c9f.f000 (MAC In Use)
Local virtual MAC address is 0000.0c9f.f000 (v2 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 0.016 secs
Preemption enabled
Active router is local
Standby router is unknown
Priority 150 (configured 150)
Group name is "hsrp-Vl10-0" (default)
Standby config - D12:
State is Standby
28 state changes, last state change 00:04:30
Active virtual MAC address is 0000.0c9f.f000 (MAC Not In Use)
Next hello sent in 0.736 secs
Preemption enabled
Active router is 10.10.10.1, priority 150 (expires in 8.672 sec)
MAC address is 5254.0000.800a
Standby router is local
Priority 100 (default 100)
D12(config-if)#
where and how did you apply the access lists ? Post the full running configurations of both routers, as it is not visible from the snippets you posted what the access lists do.
your access list is wrong and breaks the HSRP neighborship.
Use the one I suggested.
All sw must have same vtp domain
hnavi77
Hello Georg,
I am not using any acl on my configuration.
The one i used is only for filtering ip traffic with the debug ip packet ACL.
Config of D11:
Current configuration : 3006 bytes
! Last configuration change at 17:27:25 UTC Fri Apr 29 2022
version 15.2
service compress-config
hostname D11
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip igmp snooping
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0
negotiation auto
negotiation auto
negotiation auto
interface GigabitEthernet0/3
negotiation auto
interface Vlan10
standby version 2
standby 0 preempt
ip forward-protocol nd
ip http server
ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec ^C
IOSv - Cisco Systems Confidential -
Supplemental End User License Restrictions
This IOSv software is provided AS-IS without warranty of any kind. Under no circumstances may this software be used separate from the Cisco Modeling Labs Software that this software was provided with, or deployed or used as part of a production environment.
By using the software, you agree to abide by the terms and conditions of the Cisco End User License Agreement at http://www.cisco.com/go/eula. Unauthorized use or distribution of this software is expressly prohibited.
^C
banner incoming ^C
^C
banner login ^C
^C
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
D11(config-if)#
Config of D12:
D12(config-if)#do sh run
Current configuration : 2982 bytes
! Last configuration change at 14:31:46 UTC Fri Apr 29 2022
version 15.2
hostname D12
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip igmp snooping
no ipv6 cef
negotiation auto
negotiation auto
negotiation auto
negotiation auto
interface Vlan10
standby version 2
standby 0 preempt
ip http server
control-plane
banner exec ^C
^C
banner incoming ^C
^C
banner login ^C
^C
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
end
D12(config-if)#
hnavi77
Hello  MHM,
i am not using trunk configuration at all from the swithes, so VTP is useless for my topology.
i am using access port with vlan 10 only. I am trying to have a simple topology to understand this issue. Because i am having similar issue in my more complex topology.
A couple things you could try.
Connect a cable between the two HSRP devices and eliminate traffic going through the switch. First make it an access port like you did. If it works is might be a switch config issues (still not sure what)
If that doesn't work change that link you just added (bypassing the switch) into  a trunk to see if that works.
Second thing to try is make all links (except PC link) a trunk to see if that fixes it.
It could narrow down some issues for you
Hope that helps
-David
friend
even if you config SVI still both SW is L2 you need command
ip routing
to make them L3 SW.
