CIsco C1111-8P routers disabling SSH
Hello guys.
We have deployed new Cisco 1111-8P routers in most of our branches, but what i have been noticing lately is that the routers will suddenly become unaccessible via ssh, when we login via console, we can see that ssh is disabled, we have to re-enable ssh by generating a new key. My question is why does the router after a certain period of time disable ssh? what is causing this?
Regards.
Mark Elsen
 - That normally should not happen,  make a working ssh-config (again) and save it , change your administrative-passwords, to prevent unauthorized tampering with the device. Make sure only allowed-persons can have admin-access , if you are not up to doing that already then you may also  send logs to syslog when config is  changed and and or for tracking user-activities. Use these steps :
1. enable
2. configure terminal
3. archive
4. log config
5. logging enable
6. logging size entries
7. hidekeys
8. notify syslog
9. end
 M.
hello @Mark Elsen
Thanks for the help but i dont think its due to some unauthorized changes happening on the routers as it is only happening on the 1111-8P's and not the other models we have in our environment, can the licensing be the cause? see output for the license below
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing is DISABLED
Hello
Have you tried to make the ssh connections persistant?
show transport-map all
Example:
transport-map type persistent ssh sshhandler
connection wait allow
rsa keypair-name sshkeys
authentication-retries x
transport interface x/x
Kind Regards
Paul
