Cisco C3945 support the NAT ALG function?
I would like to know Cisco C3945 routers can support NAT ALG function? Is this feature enabled by default? How to check whether this function is enabled?
pieterh
the obvious command to check if it is enabled would be
     show running-config view full | include ALG
the page to check if current hardware + software version support this would be
Cisco Feature Navigator
