Cisco C3KX-NM-10G Catalyst 3K-X 10G Network Module swap
Have a Cisco C3KX-NM-10G Catalyst 3K-X 10G Network Module. How long do you think it would take for the 3750X Series Catalyst Switch to recognize the new module?
Is it hot swappable?
Can 1GB SFP transceivers work fine in this?
Thanks!!
Replying to my own message here...
Was able to replace the module HOT but having trouble with a single 10G connection in slot #4. Might be another issue but thought you should know.
Hello Elvis
Try this link and use this flavors:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/net_mod_note.html
Slot 2 with one 10-Gigabit SFP+ module and Slots 3 and 4 with 1-Gigabit SFP modules
Slot 2 and Slot 4 each with 10-Gigabit SFP+ modules
Let me know how it goes.
Good luck!
