Cisco C819G-4G-G-K9 - LTE Vodafone Germany
sebastian.lemke
Hi all,
I am trying to configure a Cisco 819G-4G router to work with Vodafone LTE in Germany.
I already read through the Cisco documentation and through several posts in this forum, but am not able to connect to the internet.
Can somebody help? I assume, I just missed anything anywhere ;-)
Config & Output see attachment.
Thanks!!
6 Replies 6
mike.fritzsche
Hi Sebastian,
have you configured the username and password in profile?
cellular 0 lte profile create 1 web.vodafone.de pap username password
Best regards
Mike
Hi Mike,
thanks for your reply.
Yes, I configured:
cellular 0 lte profile create 1 web.vodafone.de chap vodafone vodafone
(note chap instead of pap)
Currently it looks like Vodafone hasn't activated the card for LTE data
As soon as that is sorted out, I will update this post...
Hi Sebastian,
The SIM-card I used is working well via USB.
Do you use the password: vodafone?
I have manually configured the PIN via:
cellular 0 lte sim unlock xxxx
Mike
Hi Sebastian,
now LTE is running at C819-4G.
Your configuration is right:
Best regards
Mike
Great!
Could you post your whole working config?
Hi Sebastian,
It was very important to set the right properties of provider data!
For Vodafone you have to set:
Access Point Name (APN) = web.vodafone.de
Authentication = chap
Username: vodafone
Password: vodafone
Router01#cellular 0 lte profile create 1 web.vodafone.de chap vodafone vodafone
To set the PIN of SIM card you have to configure:
Router01#cellular 0 lte sim unlock 1234
Mike
