08-14-2024 02:35 PM
I have a question regarding the Cisco C8300-2N2S-6T.
We are looking for the details of the ground lug and screw for the Cisco C8300-2N2S-6T. We use this information in case we lose the grounding lug and screws.
Will Salzbrener
08-14-2024 11:40 PM
- Ref : https://www.cisco.com/c/en/us/td/docs/routers/cloud_edge/c8300/hardware_installation/b-catalyst-8300-series-edge-platforms-hig.pdf
Look for screw and ground lug with find in the browser to get details on the components that you are mentioning ,
M.
08-15-2024 06:48 AM - edited 08-15-2024 06:49 AM
Appreciate the help.
I am unable to discern the ground screw and lug from the docuement.
The lug is suggests a certain range. In addition there is no information for the spacing. The lug is a 2-hole lug.
There is no mention of the screw size needed, especially the length. If we used the right size, but was too long, we could damage the equipment.
Will Salzbrener
08-15-2024 11:05 AM - edited 08-15-2024 11:19 AM
Hello @Will Salzbrener ,
on page 45 of the document provided by @Mark Elsen
>> For grounding, use size 6 AWG (13 mm² ) copper wire and the ground lug provided in the accessory kit.
and
>> This equipment must be grounded. Never defeat the ground conductor or operate the equipment in the absence
of a suitably installed ground conductor. Contact the appropriate electrical inspection authority or an electrician
if you are uncertain that suitable grounding is available. Statement 1024
Edit:
reviewing your initial post I see I have misunderstood your question.
You would like to find the tech specifications of the ground lug.
We can just see Figure 31 on page 47
Hope to help
Giuseppe
08-15-2024 11:45 AM
Giuseppe,
That is correct I need to know the detail specifications of the ground lug and screw.
e.g. for lug
Stud hole size = 4.8mm, Stud Hole Spacing = 16mm
e.g. for screw
M4 x 0.7mm, 6mm long
Will Salzbrener
08-27-2024 01:13 PM
I have found that the P/N of the Accessory Kit is: 69-0328-01. Can someone please pass on the details of the Accessory kit, which would include the dimensioning needed above or the part numbers of the lugs and screws?
Will Salzbrener
10-15-2025 06:16 AM
Our team is also looking for an answer for the details of the grounding lug and screw. The team plans to use the following
TERMINAL LUG, 2X #10HOLE, 8AWG, 0.63 SPACING
WASHER, FLAT, 18-8 SSTL, M4, 4.30MM ID, 9MM OD, 0.9MM THK
WASHER, LK, 18-8 SSTL, M4, 4.1MM ID, 7.6MM OD, 1.0MM THK
SCREW, PAN HEAD, 18-8 SSTL, M4X0.7MM, 12MM LG
