Cisco c837 basic conf cannot access skype
Yashas Sridat
Hello guys,
Below my actual conf for cisco c837... the problem is that i cannot access skype if i plug my laptop in any port from f1-4 but web browsing is ok except for some websites such as malwarebytes and viber (webpage cannot be displayed).
what wrong with this conf..
any one out there can help me?
version 12.4
no service pad
hostname SOHO
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.0 10.10.10.30
ip dhcp pool LAN
network 10.10.10.0 255.255.255.0
domain-name SYS.local
default-router 10.10.10.1
dns-server 202.123.2.6 202.123.2.11
lease 0 4
ip cef
ip domain name SYS.local
ip name-server 202.123.2.6
ip flow-cache timeout active 1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
login on-failure every 65535
login on-success every 65535
crypto pki trustpoint TP-self-signed-2896821387
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2896821387
revocation-check none
rsakeypair TP-self-signed-2896821387
crypto pki certificate chain TP-self-signed-2896821387
certificate self-signed 03
3082024E 308201B7 A0030201 02020103 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32383936 38323133 3837301E 170D3136 30313331 31393136
35375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 38393638
32313338 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B63D B2E5A19D 3120DFBC B03894A2 0DD00F18 C7D7B9DD D45702F0 6C497276
77F9321F E35D376C DF6012E3 A4E9353A CCA5B61B 754016F2 A1A907A9 86165AFE
32B500C5 58B7B001 B0E7AC67 82B03338 49EE5B13 7DFC30C7 F712E521 9DD67785
A0EA5837 17D0E09F 63C49AB3 36EF91E2 B720E3AA E44970DC FC4B183F 8EEF1AB9
AF070203 010001A3 76307430 0F060355 1D130101 FF040530 030101FF 30210603
551D1104 1A301882 16414453 4C5F484F 4D455F31 4D2E5359 532E6C6F 63616C30
1F060355 1D230418 30168014 647154F6 CCAA1E35 E45A9DF5 62C370AD EB2AC3EA
301D0603 551D0E04 16041464 7154F6CC AA1E35E4 5A9DF562 C370ADEB 2AC3EA30
0D06092A 864886F7 0D010104 05000381 81007D80 3D8CBE27 EE1317FB E123F5CF
41A50972 AE40B3F0 232F0494 2D4751CF 0E142B98 84D63597 AE6D3726 0DC55880
4CF4B3BF 04C0B07B AC9B773B EDA7FF49 3BF440D1 3438821E 523542A9 9B4662EC
31543AA4 C69CB937 9BE1809D 32A93C50 F27D0F20 FCB2F909 6CFEAFFA F951D929
605A23D7 AD25A0AF 75AFD704 C61475A3 11A2
quit
interface Ethernet0
description LAN
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
description DSL_OPERATING
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer0
description WAN
ip address negotiated
ip nat outside
ip virtual-reassembly max-reassemblies 1024
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname sheshir627@plus
ppp chap password 7 071C385F5C001D0403
ppp pap sent-username sheshir627@tplus password 7 120A1C04000208053E
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
ip default-gateway 10.10.10.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip flow-export source Ethernet0
ip flow-export version 9
ip flow-export destination 10.10.10.3 2055
ip nat inside source list 101 interface Dialer0 overload
access-list 101 permit ip 10.10.10.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 0 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Philip D'Ath
I'm not convinced it is your config with the issue, but try adding the below.  If it makes no differences take it back out again.
interface Dialer0
 ip tcp adjust-mss 1400
Philip D'Ath
interface Dialer0
Hello Sir,
Thank you very much for this line :)
It did help me :D
by the way can I increase it to 1460 or it other issues?
Sure.  If it causes a problem just lower it again.
I tend to go with 1400 these days as it pretty much works wit everything - and although 1460 is "technically" better - I defy you to produce any measurable difference.
Thank you very much sir.
I was having another issue with another website www. myjob. mu and i had to set another command along with
interface Dialer0
it the MTU size
interface Dialer0
ip mtu 1496
Everything working smooth now. :)
Shesh Y Sridat
