Cisco C881-K9 Default License
AI99
I have a Cisco C881 router (part number C881-K9) installed at remote site.
I configured LAN with DHCP server, WAN, GRE over IPsec VPN tunnel for communication with HQ, EIGRP routing protocol.
The router is installed and operational with no valid license. What are the drawbacks in terms of performance ??
Here's the output of "show version" and "show license":
Router881#show version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 30-Jan-14 02:12 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T, RELEASE SOFTWARE (fc1)
Router881 uptime is 1 hour, 25 minutes
System restarted at 07:25:40 LB Fri Aug 3 2018
System image file is "flash:c800-universalk9-mz.SPA.153-3.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C881-K9 (revision 1.0) with 988236K/60339K bytes of memory.
Processor board ID FCZ**********
5 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C881-K9               FCZ**********
License Information for 'c800'
    License Level: advipservices   Type: Default. No valid license found.
    Next reboot license Level: advipservices
Router881#
Router881#show license
Index 1 Feature: advipservices
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: advsecurity
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Priority: Medium
Index 3 Feature: ios-ips-update
Router881#
in short, there are no drawbacks. The 'advipservices' features are installed and fully functional. You should accept the EULA though ('license accept' command).
advsecurity is the default license, issue below command:
Router(config)#license boot module c880-data level advsecurity
License State: Active, In Use
