cisco catalyst 2960CG-8TC-L problem
shiraforkosh1
I have a switch  cisco catalyst 2960CG-8TC-L (mini switch), and I can't connect to it with telnet because there is no login local on it, and I can't write on this switch this command. Does someone know the command of this switch for enable login local?
Rolf Fischer
Level 9
Level 9
please have a look at this discussion and check the aaa model: https://supportforums.cisco.com/discussion/12615466/line-console
Rolf
Try this disabling aaa authentication
enable password XXXXX
username tnhaccess password 0 XXXXX
no aaa new-model
line con 0
stopbits 1
line vty 0 4
exec-timeout 60 0
password 7 XXXXX
logging synchronous
login local
length 0
transport input telnet ssh
line vty 5 15
exec-timeout 60 0
password 7 XXXXX
logging synchronous
login local
***Please rate all the useful posts***
-Prabath
