Cisco catalyst 4600
zathura43
hopefully this a simple question, I have a cisco router and switches, I would like to know how to upgrade the firmware
Thank you very much for you response, I have cisco 4006 catalyst & switch, In order to me to upgrade the firmware I need to download firmware file & tftp file am I correct, other thing is can I upgrade thru a windows or telnet.
since I'm a little confused, could you give me step by step instruction.
Hi Friend,
I believe you must be running CATOS on your switch and you are right that you need to download image frrom cisco website and then install tftp server on your machine and then you can upgrade image from tftp server which is installed on your machine to switch.
This link will give you step by step instructsions to upload image on switch using tftp server
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/config/images.htm#1019898
HTH, if yes please rate the post.
Ankur
