Cisco Configuration Professional Password Recovery Error
derrickcameron
All,
My co-worker logged into a Cisco 1941 running Cisco Configuration Professional. Unfortunately they didn't enter a new username and password so the device is now locked out. What can I do to recover this device?
What I've tried
-Break to get it into Rommon (Password Recovery Disabled in Cisco Configuration Professional)
-Removing Flash (Just Boot Loops)
-Break after IOS loads to reset config (Procedure for normal instance of Password Recover Disabled)
Please advise I'm running out of ideas.
devils_advocate
Level 7
Level 7
I don't use CCP so am unsure if you can do it via the software.
Can you get a console cable, boot into ROMMON and do it that way?
I'm sitting next to the device consoled in. I can't get it to go to rommon mode. It has PASSWORD RECOVERY FUNCTIONALITY IS DISABLED.
