Cisco console terminal server
lachimi-sanyasi
Hi People,
I have an  issue with my ISR4221/K9 that I am setting up for the Cisco console terminal server.
Here is my config:
hostname HOBART-CONSOLE
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa authentication login console local
aaa session-id common
clock timezone acst 9 30
clock summer-time ACDT recurring 1 Sun Oct 3:00 1 Sun Apr 3:00
ip host R1 2002 2.2.2.2
ip host R2 2003 2.2.2.2
ip host R3 2004 2.2.2.2
ip host R4 2005 2.2.2.2
ip host R6 2007 2.2.2.2
ip host R7 2008 2.2.2.2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface GigabitEthernet0/0/0
description UPLINK LAN
ip address 10.117.98.252 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
media-type rj45
negotiation auto
interface Async0/1/0
no ip address
interface Async0/1/1
no ip address
interface Async0/1/2
no ip address
interface Async0/1/3
no ip address
interface Async0/1/4
no ip address
interface Async0/1/5
no ip address
interface Async0/1/6
no ip address
interface Async0/1/7
no ip address
interface Async0/1/8
no ip address
interface Async0/1/9
no ip address
interface Async0/1/10
no ip address
interface Async0/1/11
no ip address
interface Async0/1/12
no ip address
interface Async0/1/13
no ip address
interface Async0/1/14
no ip address
interface Async0/1/15
no ip address
line con 0
transport input none
stopbits 1
line aux 0
line 0/1/0 0/1/15
exec-timeout 0 0
timeout login response 10
privilege level 15
logging synchronous
login authentication local
no exec
transport input telnet
transport output telnet
stopbits 1
flowcontrol hardware
line vty 0 4
password Nyrstar
logging synchronous
login authentication console
length 0
transport input ssh
line vty 5 15
password Nyrstar
logging synchronous
length 0
transport input ssh
Can you please tell me where I am making mistake?
It will ask me the username and password when i type R1 but after giving the username and password it doesn't do anything. it just stuck doing nothing.
M02@rt37
Hello @lachimi-sanyasi
On your async lines 'line 0/1/1-0/1/15' add the command modem inout
Without it, the router won’t treat the line as a bidirectional terminal line, and your session won't connect.
Best regards
This is what i did as per your advice
line 0/2/0 0/2/15
exec-timeout 0 0
privilege level 15
logging synchronous
modem InOut
transport input all
It is still not working
