Cisco CPE MLFR Question
richchiuve
I have  a Cisco 2801 w/ WIC - T1 CSU/DSU. I want to upgrade to a 2xT1 Internet circuit and I need another T1 module. However, the WIC - T1 CSU/DSU is EOL and has been replaced by a HWIC-1DSU-T1 module. Does anyone know of any problems running Multi-Link FR if one module is a WIC and the other module is an HWIC? Would I be better off replacing the WIC-T1 with two HWIC-T1's or a VWIC2-2MFT?
Giuseppe Larosa
Hello Richchiuve,
It shouldn't be a problem they are still two T1 on the same router.
Do not disable frame-relay arp on member links and follow examples in CCO (someone had troubles doing that operation)
see
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_ml_fr_frf161_ps6350_TSD_Products_Configuration_Guide_Chapter.html
Hope to help
Giuseppe
