How do i find if the DSU value is set to default or not in the NM-1 E3 as i am getting the following error message "dsxpnm_gt96k_abort_rx_mpsc:Aborting Rx mpsc failed"
vmandala
How do i find if the DSU value is set to default or not in the NM-1 E3 as i am getting the following error message "dsxpnm_gt96k_abort_rx_mpsc:Aborting Rx mpsc failed". I see there is a bug match for this error. But need to confirm it?
paolo bevilacqua
Since your profile indicates that you are a Cisco employee, I would suggest that you use the many internal resources available to you to answer your questions.
This to avoid giving readers the impression that your best support method is a free customers' forum.
