Cisco CSR in AWS with GRE/IPsec Tunnel
dbrossart1
I posted this as a reply to another discussion, but I thought it would be better separate.
We have a Cisco CSR 1000 as an AWS EC2 instance with two interfaces.  We have a tunnel setup with a customer.  We have an AWS server that can communicate with the local (inside) interface.  There is a device that is connected to the customer network that we need that device to communicate to the server and vice versa.
CSR:
GigabitEthernet1      172.31.61.118/24 DHCP
GigabitEthernet2      172.31.43.254/20 Static
Tunnel0                     192.168.0.2/30
Tunnel0 Source       172.31.61.118
IP Route
Gateway of last resort is 172.31.61.1 to network 0.0.0.0
S*   0.0.0.0/0 [254/0] via 172.31.61.1
     100.0.0.0/23 is subnetted, 1 subnets
B       100.126.16.0 [20/0] via 192.168.0.1, 01:00:47
     172.31.0.0/16 is variably subnetted, 4 subnets, 3 masks
C       172.31.32.0/20 is directly connected, GigabitEthernet2
L       172.31.43.254/32 is directly connected, GigabitEthernet2
C       172.31.61.0/24 is directly connected, GigabitEthernet1
L       172.31.61.118/32 is directly connected, GigabitEthernet1
     192.168.0.0/24 is variably subnetted, 4 subnets, 2 masks
C       192.168.0.0/30 is directly connected, Tunnel0
L       192.168.0.2/32 is directly connected, Tunnel0
Server:
Ethernet 1                 172.31.33.203/20 gw 172.31.32.1
Device:
Ethernet 1                 100.126.16.1/23
Currently, this is what's happening:
I can ping the 172.31.33.203 via 172.31.43.254 on the CSR and vice versa.
I can't ping the 172.31.33.203 via 172.31.61.118 on the CSR and vice versa.
I can ping the 192.168.0.0/30 IPs via 172.31.43.254 on the CSR
I can’t ping the 192.168.0.0/30 IPs via 172.31.61.118 on the CSR
I can’t ping the 192.168.0.0/30 IPs via 172.31.33.203
I can’t ping 100.126.16.1 from anywhere in AWS
The device 100.126.16.1 can ping 172.31.43.254, but nothing else.
Is there some static routes that I’m needing to implement in AWS to get this to work?
I’m not very familiar with Cisco and less familiar with AWS networking.
Any help would be greatly appreciated!
Philip D'Ath
It almost sounds like routing is turned off.  Try adding this to the config:
ip routing
I added that, but was still unable to ping through any interface on the router.
