08-28-2024 05:57 AM
I have worked with the 28xx/38xx/29xx/39xx series routers for 20+ years with their LMR feature set and E&M cards. To my understanding this has been discontinued in newer models even though the 8200 series routers has an E&M card, I assume it does not allow for LMR Feature set to connect Land Mobile Radio tone and E&M wireline connections.
Correct?
08-28-2024 10:06 PM
Hello @Rob Anderson ,
do you refer to the following feature LMR with analog ports ?
it looks like there are also license requirements to use the feature.
Hope to help
Giuseppe
08-29-2024 03:41 AM
Correct,
That is it, however I believe the 4200/4300/4400 ISR routers are end of life. I was wondering if anyone had tested with the 8300 router?
I see there is a E&M FGD module available for the 8300, but appears to be used for PBX connections.
"The original design guide for LMR does not cover the required items for the latest generation of Cisco Voice Gateways. Hence, this document aims describes the LMR / Hootie feature in regards to IOS-XE devices such as ISR 4300 and 4400 series voice gateways."
