Cisco Embedded Event Manager asr9k help
ares
Dears
I want to create EEM to ACL "192.168.1.0/24 next hope 192.168.2.2"  starting from 10:00 AM to 11:00 AM
please help me how I create this ACL from EEM
I tried to create EEMS but in my ASR router doesn't show Applet command
please check the details
(config)#event manager ?
directory                        Set Embedded Event Manager directory information
environment                  Set an Embedded Event Manager global variable for policies
policy                            Register an Event Manager policy
refresh-time                  Set refresh time (in seconds) for policy username's AAA taskmap
scheduler                      Set Embedded Event Manager scheduler options
test-client                      Embedded Event Manager test-client(cisco-support)
(admin)#show platform
Node Type State Config State
0/RSP0/CPU0 ASR9001-RP(Active) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP ASR-9001-FAN READY
0/0/CPU0 ASR9001-LC IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/PM0/SP A9K-750W-DC READY PWR,NSHUT,MON
0/PM1/SP A9K-750W-DC READY PWR,NSHUT,MON
System image file is "bootflash:disk0/asr9k-os-mbi-5.1.2/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
iosxr-security, V 5.1.2[Default], Cisco Systems, at disk0:iosxr-security-5.1.2
Built on Wed Apr 30 18:55:22
By iox-lnx-004 in /auto/srcarchive7/production/5.1.2/all/workspace for pie
asr9k-k9sec-supp, V 5.1.2[Default], Cisco Systems, at disk0:asr9k-k9sec-supp-5.1.2
as far as I recall, EEM applets are not supported in XR (which runs on your ASR9K). You need to configure Tcl policies. See the link below:
Configuring and Managing Embedded Event Manager Policies
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/system_monitoring/configuration/guide/b_sysmon_cg42asr9k/b_sysmon_cg42asr9k_chapter_010.pdf
