Cisco EtherSwitch 4-Port High-Speed WAN Interface Cards
saimbt
We are planning to connect site A and site B through metro ethernet (ethernet for WAN connectivity). Was wondering can we use HWIC-4ESW cards?
Ref:- http://cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016bf0b.html
-Sai.
You might want to check out the following doc which compares it with the EtherSwitch network modules:
http://www.cisco.com/en/US/products/ps5855/products_qanda_item0900aecd802a9470.shtml
Hope that helps - pls rate the post if it does.
Paresh
pkhatri
Level 11
Level 11
Sai,
You certainly can use these cards for that purpose. However, you need to be aware of some limitations associated with the card, such as the fact that you can't use them as routed ports, as you can with the Etherswitch Network Modules.
But if that is not what you are after, then they should be fine.
Paresh
Paresh
Bulls Eyeeeeeeeeeeeeeeeeeeeeee..
i managed to get to this page but somehow missed out on this info..
I have rated the post.
Thanks a ton.
-Sai.
