01-16-2011 12:30 PM - edited 03-04-2019 11:06 AM
I erased my flash and cannot locate an IOS that will fit on my 2610 router, I was running 11.3(7), but cannot locate anything even close. Any ideas?
01-16-2011 01:28 PM
The 2600 series is EOL and so are all the old IOS versions for it. No much you can do with 4Mb flash anymore
01-16-2011 01:35 PM
Hi Reza,
Yes, you are correct. Then again, I assume that the OP was using the 2600 for some purpose and we could at least help him get the router back on its feet to do the (simple) job it was doing till now.
I suggest using the Cisco IOS Feature Navigator tool available at the http://cisco.com/go/fn to look up an appropriate IOS for the router that can fit into its FLASH and DRAM.
Best regards,
Peter
01-16-2011 02:34 PM
Hi Peter,
I am all about helping, but unfortunately there is no IOS that fits in 4Mb flash. Below IOS is the earliest IOS (none differed) you can download, but the requirement is to have a minimum of 8Mb flash. I am not sure if the OP has a service contract to download the IOS since the 2600 series has ben EOL for a while now and it is no longer supported by Cisco.
IP/IPX/AT/DEC | |
c2600-d-mz.122-26c.bin | |
Release Date: 01/AUG/2007 | |
Size: 6098.54 KB (6244900 bytes) | |
Minimum Memory: DRAM:32MB Flash:8MB |
Reza
