Cisco IOS Upgrade Help
RBM01991
Good morning team,
I'm upgrading the IOS on my 3945 this morning, and I think I accidentally deleted something I wasn't supposed to. Now I was able to do recovery via ROMMON and the tftpdnld -r command and get the upgraded image loaded into the router successfully.
However I did a reload command to see if the device would reboot like normal and it booted into ROMMON again and it said it could not open the IOS image..
So I used the following command to set the boot image:
boot system flash flash0:c3900-universalk9-mz.SPA.157-3.M5.bin
Hit reload again and it still booted into ROMMON and I had to do the tftpdnld -r command to reload the image.
So what am I missing? Below is the sh ver output.
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.7(3)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 27-Sep-19 06:44 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M13, RELEASE SOFTWARE (fc1)
HomeRouter-001 uptime is 29 minutes
System returned to ROM by reload at 13:05:27 EST Tue Dec 31 2019
System image file is "tftp://192.168.1.2/c3900-universalk9-mz.SPA.157-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 1835264K/261888K bytes of memory.
Processor board ID FTX1601AHU4
1 FastEthernet interface
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash 0 (Read/Write)
250880K bytes of ATA CompactFlash 1 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        C3900-SPE150/K9
Suite License Information for Module:'c3900'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
datak9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information for Module:'c3900'
Technology    Technology-package                  Technology-package
              Current              Type           Next reboot
ipbase        ipbasek9             Permanent      ipbasek9
security      securityk9           Permanent      securityk9
uc            uck9                 Permanent      uck9
data          datak9               RightToUse     datak9
6 Replies 6
Oleg Volkov
Hi.
In ROMMON enter dev and look at available devices, then do dir bootflash: or other available devices.
Do “set” and check BOOT variable
Helping seriously ill children, all together. All information about this, is posted on my blog
Should be
boot system flash0:c3900-universalk9-mz.SPA.157-3.M5.bin
Kind Regards
Paul
Leo Laohoo
Console into the router and reboot the router. I want to see what the router is trying to do.
Copyright (c) 2011 by cisco Systems, Inc.
Total memory size = 4096 MB - DIMM0 = 2048 MB, DIMM1 = 2048 MB
CISCO3945-CHASSIS with C3900-SPE150/K9 with 4194304 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x4000000, size: 0x18fa0
loadprog: error - not an executable ELF file
boot: cannot load "flash:"
boot: cannot load "flash:c3900e-universalk9-mz.SPA.157-3.M5.bin"
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash0:c3900-universalk9-mz.SPA.157-3.M5.bin"
boot: cannot load "flash0:"
boot: cannot determine first executable file name ondevice "flash1:"
rommon 1 >
That's what it does.
Wait ... ISR G2 ... Why is the boot variable string point to "flash0:" and "flash1:"?
There's only one and it's called "flash:".
Post the complete output to the command "dir flash:" (in ROMMON).
Never mind guys I figured it out. I just removed the second flash card, and did a standard copy tftp flash command and it works just fine now.
