12-10-2023 05:44 PM
I am running 17.9.04a on a C1111-8PLTEEAWB and trying to set up the DHCP client so that I can connect it to my ISP's Fiber ONT instead of their provided eero router without losing my IP address. The eero will faithfully get the IP it wants back, even after a long outage... I can power-cycle the ONT and get a new address, but really want to get mac-cloning working.
interface GigabitEthernet0/0/0
description connected to Internet
mac-address 5027.a92d.ffff
ip dhcp client client-id ascii eero
ip dhcp client broadcast-flag clear
ip dhcp client class-id ascii
ip dhcp client hostname eero
ip dhcp client option 50 ip 47.***.***.***
ip address dhcp
negotiation auto
I am looking at the IP Addressing Configuration Guide, Cisco IOS XE 17.x and other Cisco docs that allowed me to get part of the way, using commands like "ip dhcp client broadcast-flag clear" to set the unicast bootp flag.
FYI - I am not able to use the command "ip dhcp client vendor-class disable" that is referenced.
packet capture of eero discover that gets a response and successfully negotiates the requested IP address:
No. Time Source Destination Protocol Length Info
3 20:52:50.827999 0.0.0.0 255.255.255.255 DHCP 342 DHCP Discover - Transaction ID 0x7deccd76
Frame 3: 342 bytes on wire (2736 bits), 342 bytes captured (2736 bits) on interface \Device\NPF_{55FDD48B-D4C7-4C49-9A40-88F5C0C4155B}, id 0
Ethernet II, Src: 50:27:a9:2d:ff:ff (50:27:a9:2d:ff:ff), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol Version 4, Src: 0.0.0.0, Dst: 255.255.255.255
User Datagram Protocol, Src Port: 68, Dst Port: 67
Dynamic Host Configuration Protocol (Discover)
Message type: Boot Request (1)
Hardware type: Ethernet (0x01)
Hardware address length: 6
Hops: 0
Transaction ID: 0x7deccd76
Seconds elapsed: 10
Bootp flags: 0x0000 (Unicast)
Client IP address: 0.0.0.0
Your (client) IP address: 0.0.0.0
Next server IP address: 0.0.0.0
Relay agent IP address: 0.0.0.0
Client MAC address: 50:27:a9:2d:ff:ff (50:27:a9:2d:ff:ff)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: DHCP
Option: (53) DHCP Message Type (Discover)
Option: (50) Requested IP Address (47.***.***.***))
Option: (12) Host Name
Option: (55) Parameter Request List
Length: 13
Parameter Request List Item: (1) Subnet Mask
Parameter Request List Item: (28) Broadcast Address
Parameter Request List Item: (2) Time Offset
Parameter Request List Item: (3) Router
Parameter Request List Item: (15) Domain Name
Parameter Request List Item: (6) Domain Name Server
Parameter Request List Item: (119) Domain Search
Parameter Request List Item: (12) Host Name
Parameter Request List Item: (44) NetBIOS over TCP/IP Name Server
Parameter Request List Item: (47) NetBIOS over TCP/IP Scope
Parameter Request List Item: (26) Interface MTU
Parameter Request List Item: (121) Classless Static Route
Parameter Request List Item: (43) Vendor-Specific Information
Option: (255) End
Padding: 0000000000000000000000000000000000000000000000000000000000
Packet capture of the latest iteration of the IOS-XE DHCP Client configuration (no response from ISP's DHCP server). You will see that the Cisci IOS-XE DHCP client is adding in options 60,61, and124
I do not know if these are causing the ISP DHCP Server to not respond or if it is something else, but I would like to remove them (I am successful at *changing* the host identifier, the client identifier, and the vendor class identifier, and , but I really need to 'eliminate' them from being sent at all in the DHCP Discover message.
1 23:18:13.503795 0.0.0.0 255.255.255.255 DHCP 349 DHCP Discover - Transaction ID 0x4954c014
Frame 1: 349 bytes on wire (2792 bits), 349 bytes captured (2792 bits) on interface \Device\NPF_{55FDD48B-D4C7-4C49-9A40-88F5C0C4155B}, id 0
Hops: 0
Transaction ID: 0x4954c014
Seconds elapsed: 3
Magic cookie: DHCP
Length: 1
DHCP: Discover (1)
Option: (57) Maximum DHCP Message Size
Length: 2
Maximum DHCP Message Size: 1200
Option: (61) Client identifier
Length: 5
Type: 0
Client Identifier: eero
Length: 4
Host Name: eero
Length: 8
Parameter Request List Item: (33) Static Route
Parameter Request List Item: (150) TFTP Server Address
Option: (60) Vendor class identifier
Length: 5
Vendor class identifier: ascii
Option: (124) V-I Vendor Class
Length: 21
Enterprise: ciscoSystems (9)
CableLab Address Mode: 16
NetInfo Parent Server Tag: \017C1111-8PLTEEAWB
Length: 4
Requested IP Address: 47.***.***.***)
Option: (255) End
Option End: 255
12-10-2023 08:03 PM
NO ip dhcp client request option-name
first check option name with it number' then use above to make your router not ask ISP server for it value.
Note:- I 50% suspect it not issue of option but let eliminate it from out troubleshooting.
MHM
12-10-2023 08:08 PM - edited 12-11-2023 06:05 AM
MHM
12-11-2023 05:57 AM - edited 12-11-2023 05:57 AM
I think you are responding to the wrong Forum post... this post is about ISR1100 and IOS-XR DHCP, not N3K and NX-OS.
-mike
12-11-2023 05:54 AM
Unfortunately, that is not an option for 60,61,124:
C1111(config)#int gi0/0/0
C1111(config-if)#no ip dhcp client request 60
% Invalid input detected at '^' marker.
C1111(config-if)#no ip dhcp client request ?
classless-static-route Classless static route (121)
dns-nameserver DNS nameserver (6)
domain-name Domain name (15)
netbios-nameserver NETBIOS nameserver (44)
option DHCP options
router Default router option (3)
sip-server-address SIP server address (120)
static-route Static route option (33)
tftp-server-address TFTP server address (150)
vendor-identifying-specific Vendor identifying specific info (125)
vendor-specific Vendor specific option (43)
<cr> <cr>
12-11-2023 06:06 AM - edited 12-11-2023 06:06 AM
sorry what op. your router client you dont request from server ?
12-11-2023 06:29 AM - edited 12-13-2023 05:36 AM
If you look at the packet capture from the eero router that is successful and the packet capture from the ISR1111 that is unsuccessful, the major differences seem to be options 60,61, and 124. There are also differences in option 55(parameters requested), but most of those are not allowed by the IOS-XE 17.9.4a command set.
With how the IOS-XE DHCP client sends the DHCP Discover message currently (or with default config, or any config I have tried) I get no response from the ISP DHCP Server.
My goal is to have the enterprise grade Cisco IOS-XE mimic the eero in what is commonly referred to as mac-cloning, but the ISP seems to be extra finicky..
12-11-2023 02:06 PM - edited 12-11-2023 08:03 PM
sorry I was out, now I back to home
the command you add missing "option" keyword
example below show what Ops the client will request from Server
so the correct command will be
ip dhcp client request option <then we list option of success router>
the option that we not include will not send.
MHM
12-12-2023 05:13 AM
Unfortunately 'adding' the word 'option' is not a valid command for option 60 or 61:
C1111-8PWB#conf t
Enter configuration commands, one per line. End with CNTL/Z.
C1111-8PWB(config)#interface GigabitEthernet0/0/0
C1111-8PWB(config-if)#no ip dhcp client request option 60
% Try using 'ip dhcp client option' command
% Incomplete command.
Replacing the word request with the word option is not the same feature, that is a different feature of DHCP Client.
A command like "ip dhcp client request option 4 5 7 8 9 10 11 17 18 40 41 42 66 68 69 70 71 72 73 74 75 76 124 138 141 142 160" is sending a request via option 55 to request more information be sent back FROM the DHCP Server, I am looking to configure the IOS-XE DHCP Client to send less information TO the DHCP Server.
That being said, I did enter the following DHCP commands to the configuration (they make no visible change to the interface config). You will see that the Cisco IOS-XE 17.9.4a DHCP Client is STILL sending option 60.61, and 124.
C1111-8PWB#conf t
C1111-8PWB(config-if)#no ip dhcp client option 60
C1111-8PWB(config-if)#no ip dhcp client option 61
C1111-8PWB(config-if)#no ip dhcp client option 124
% Try using 'ip dhcp client request option' command
C1111-8PWB(config-if)#no ip dhcp client request option 124
C1111-8PWB(config-if)#No. Time Source Destination Protocol Length Info
924 12:53:47.796709 0.0.0.0 255.255.255.255 DHCP 347 DHCP Discover - Transaction ID 0xeb0be620
Frame 924: 347 bytes on wire (2776 bits), 347 bytes captured (2776 bits) on interface \Device\NPF_{55FDD48B-D4C7-4C49-9A40-88F5C0C4155B}, id 0
Hops: 0
Transaction ID: 0xeb0be620
Seconds elapsed: 3
Magic cookie: DHCP
Length: 1
DHCP: Discover (1)
Length: 2
Length: 5
Type: 0
Length: 4
Host Name: eero
Length: 8
Length: 8
Vendor class identifier: ciscopnp
Length: 16
CableLab Address Mode: 11
NetInfo Parent Server Tag: \nC1111-8PWB
Option: (50) Requested IP Address (47.xxx.xxx.xxx)
Length: 4
Requested IP Address: 47.xxx.xxx.xxx
Option: (255) End
Option End: 255
Additionally, you link the 16.10.x Cisco page for IOS-XE DHCP Client when I linked the similarly, but more appropriate 17.x page for the same thing in the opening post. There are several changes introduced in Cisco IOS XE Amsterdam Release 17.2.
12-11-2023 09:02 AM
did you try use above command to remove the op60/61/124 ?
MHM
12-11-2023 09:57 AM
PLEASE actually read the contents of my replies. I literally posted the output of the router not recognizing the command, and what the IOS says are valid options for the command. Here it is again, and yes, the result is the same with 61 and 124:
C1111#conf t
option DHCP options
<cr> <cr>
C1111(config-if)#
12-12-2023 05:34 AM
I have added a screen capture and marked it up for clarity of what I am asking for.
12-12-2023 10:42 AM
Last hope then
Ip dhcp client vendor-class disable
MHM
12-12-2023 10:57 AM
So you also missed that from the original post too?
12-12-2023 10:12 PM - edited 12-12-2023 10:13 PM
Hello
@mcotherman wrote:
My goal is to have the enterprise grade Cisco IOS-XR mimic the eero in what is commonly referred to as mac-cloning, but the ISP seems to be extra finicky.
So to confirm ,your client is and IOS-XE and the dhcp server is IOS-XR.
TBH - mac cloning shouldn't be that hard to accomplish unless spoofing is being negated by the dhcp server?
In standalone DHCP sessions, the DHCP server adds an ARP entry when it assigns an IP address to a client. However, in IP subscriber sessions, DHCP server does not add an ARP entry. Although ARP establishes correspondences between network addresses, an untrusted device can spoof IP an address not assigned to it posing a security threat for IP subscriber sessions. You can enable the secure ARP feature and allow DHCP to add an ARP cache entry when DHCP assigns an IP address to a client. Secure ARP is disabled by default.
Anyhow looking at your post, could you try (no other options):
shut
ip dhcp client client-id GigabitEthernet0/0/0
ip address dhcp
no shut
