CISCO IOS-XR, Python3.7, Not able to run commands like 'ls' and 'df' o
Ann69
Cisco ios-xr router using CLI:
RP/0/RP0#show version
Thu Nov 25 07:53:59.103 UTC
Cisco IOS XR Software, Version 6.5.32.11I
Copyright (c) 2013-2020 by Cisco Systems, Inc.
RP/0/RP0#run
Thu Nov 25 07:54:05.231 UTC
[xr-vm_node0_RP0_CPU0:~]$df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 3966080 1332040 2412860 36% /
76892 11848320 43% /mnt/ecu/vdd
Using python: I am able to run show commands using Connect handler .send. Command:
from netmiko import ConnectHandler
import subprocess
Network_Device = {"host": "10.111.22.333", "username": "USER123", "password": "Pass123",     "device_type": "cisco_xr",}
Connect = ConnectHandler(**Network_Device)
Connect.enable()
version1 = "show version"
print(Connect.send_command(version1))
But not able to run 'df' or 'ls' commands, as not able to reach bash prompt i reach by running 'run' command on router.
I tried mcdvoice :
disk1files = subprocess.run("df", stdout=subprocess.PIPE)
print(disk1files.stdout.decode())
But seems its wrong. Please suggest the right library or code I can use here.
This is my first question here, so bear some silly questions or mistakes done in code
0 Replies 0
