05-24-2007 12:09 AM - edited 03-03-2019 05:07 PM
I have a cisco 2501 router with 8 MB Flash.I have two leased line of same ISP.I want to configured multilink.Which IOS is supporting.I tried c2500-i-l.113-10,c2500-i-l.120-9,c2500-d-l.112-9.
05-24-2007 12:24 AM
Always use Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Using this feature gets out for example to support MLPPP for your 2501:
c2500-i-l.12.3-22.bin
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-24-2007 02:10 AM
Thanks for ur suggetion.but my router having Flash 8MB.And image u suggest require Flash 16MB.Is there any image which support 8MB flash and multilink.
05-24-2007 02:21 AM
Yes you can use:
c2500-i-l.12.0-2a.T1.bin
HTH, please do rate all helpful replies using the scroll box on the right,
Mohammed Mahmoud.
05-24-2007 02:37 AM
Arjun,
In addition to mahmoud's post, if you dont have enough flash on the router to store the image , you can boot the router using the TFTP and have the image located in the TFTP server. Point the router to boot statement " boot system tftp://ip address/file name.bin"
-amit singh
